Circuit wheels 18x9 18x11
Old 11/30/21 | 09:37 PM
coyote_jenson's Avatar
Looking to see if these 18inch rims fit on my 2011 gt
there believe 20 + offset 18x9 and 18x11 come off a 03 mustang terminator wanted know if they fit right if stick out in rear a little its ok ...
Old 12/1/21 | 06:25 AM
Bert's Avatar
no wrong offset, pretty sure they will poke
Old 12/7/21 | 11:40 AM
m05fastbackGT's Avatar
I don't see why they wouldn't fit.. The standard 18" wheel size is 18x8" with +35mm offset.. You'll also notice an attached link below from Tire Rack which provides listings for aftermarket wheel/tire size packages for the 2011 Mustang GT.
The list includes 18x9" (front) with 45mm offset along with 18x10.5" (rear) w/38mm offset and 18x10.5" (rear) with 45mm offset.. As long as the offset range for the 18x9" wheel is between +20/+45mm, there shouldn't be any fitment nor clearance issues up front.
For 18x11" sizes, my guess is if the offset is between +35/+52mm, you'll have plenty of clearance in the rear. For my particular application, I run OEM 2007-09 Shelby GT500 wheels in 18x9.5" both front and rear which have +45mm offset and the fitment is spot on paired with 275/40/18" tires.. That being said, if they came off an "03" Cobra/Terminator, they should also fit just fine on your 2011 GT as well.
https://www.tirerack.com/wheels/resu...=Brembo+Brakes
Thomas Williams
2/28/21 09:10 PM
texasgtguy
11/2/13 09:19 PM
slowjoe24
05-09 Exterior Modifications
32
11/4/12 10:22 PM
96lasersnake
3/5/10 09:54 AM
chris_fowler99
9/28/07 01:49 PM
