Chip on my door - what to use?
Hi,
So I was in a hurry today and I pulled the key out of ignition and got out off the car. Stupid me had the key in the right hand and I closed the door with my right hand
. Even dumber, the metal part of the key was against the door as I pushed the door close.. so there's a piece of paint now that's completely gone.
It's not that noticeable but the fact is I know it's there and it bothers me. I did a search on "chip" and didn't see any results except a guy getting his whole door repainted to also correct the dent with the chip.
My dealership's sales department sells touch up paint. I've used touch up paint before on my old car and they never worked well, never blending correctly. Is that a good way to go about repairing the chip? And then apply an overcoat?
What do you guys recommend?
Sorry for noobie question.
![Grouphug](https://themustangsource.com/forums/images/smilies/grouphug.gif)
MOTM Committee Member
Hi,
Sorry for noobie question.![Grouphug](https://themustangsource.com/forums/images/smilies/grouphug.gif)
I went with the site in my first post. Color match was perfect. All I needed was the 2 oz bottle of GB Base, and the 2 oz bottle of clear
I say use genuine Ford touch up paint and built up some thickness with the paint till it matches the original paint, then sand it down with 2000 grit sandpaper and buff it out . Did that with my Escape after receiving a big rock from a semi and making a big paint chip where the satellite antenna sits on the roof, and it came back like new. Had to put about 9 coats of paint to make it even with original paint.
I just touched up some chips on my door with paint from www.touchuppaintonline.com. it came out really good and the paint matched perfectly. you just have to apply VERY little at a time to make sure the paint stays even height wise. Otherwise, you might have to do a little sanding
