Check in: what has FAILED, BROKEN or worn out on your '10+ Mustang?
Old Mar 21, 2014 | 04:06 PM
wheelman's Avatar
Originally Posted by FromZto5
All this talk about those pony projectors degrading... Eek. Makes me love my projector less car even more.
Ford figured out the problem and it gets fixed under warranty, so the issue is resolved. I couldn't care less about them other than I don't want messed up stuff on my car, but they are an excellent conversation starter. Some people's expressions when they see them are hilarious.
Old Mar 22, 2014 | 07:48 PM
70monte's Avatar
2014 base GT with automatic.
At around 4,400 miles had the radio display replaced under warranty due to etching/ fogging.
I'm at about 4,900 miles now and since replacing the Roush AB with the GT500 AB, I can now hear something that sounds like drivetrain noise. Driveshaft or rear end. I replaced the rear diff fluid at around 4,000 miles when I installed a Ford aluminum diff cover and the fluid was gray in color. That is all for now.
Wayne
Old Mar 22, 2014 | 08:03 PM
TomServo92's Avatar
2011 V6 Pony Package - Power seat rack died at 45K.
Old Mar 22, 2014 | 08:26 PM
Godzilla 5.0's Avatar
2014 GT premium 1800 miles. At 1000 miles passenger side pony light fell out going down the highway. Dealer fixed for free. No other problems other than that.
Old Mar 22, 2014 | 10:09 PM
MJJ's Avatar
MJJ
2011 GT500
800 miles - bent axle (no i didn't hit anything)
Old Mar 22, 2014 | 10:48 PM
PJRManagement's Avatar
Currently a Corvette Owner!
2011 GT Premium, Race Red, Rapid Spec 400A, 6AT, Electronics Package, Comfort Package. 12k miles. A lot of items, more than I'm used to for a new car, frankly. But...I love the way it looks and drives, it is the first car I've ever tracked, and Ford has given me a FREE 3-year maintenance plan and a FREE bumper-to-bumper warranty extension up to 5 years (up from the standard 3 years) - both for my troubles. Here's my laundry list:
* rattle in rear-view mirror, replaced under warranty.
* passenger-side seat heater fail, replaced under warranty.
* driver-side seat motor fail, replaced under warranty.
* driver-side weather stripping warped, replaced under warranty.
* driver-side window scratches, replaced under warranty.
* front LCA (control arm) creaks, TSB, replaced under warranty (with new heat-shield-fix).
* Sync not recognizing USB, uploaded new TSB software, fixed under warranty.
* interior dome/map light assembly loose, fixed under warranty.
* various squeaks in and around dash, IP, A-pillar plastics, & vents - I took some black-colored foam material and wedged into many crevices using a small flat-head screwdriver, all squeaks gone - invisible and free fix.
There it all is.
Old Mar 22, 2014 | 11:22 PM
UOP Shadow's Avatar
2013 GT500
SYNC continues to do whatever it wants whenever it wants.
Old Mar 22, 2014 | 11:34 PM
DarrenGT's Avatar
i'm at 14,900 km on my 13 GT. Radio LCD replaced. Sync sucks and so far that's it.
Old Mar 22, 2014 | 11:39 PM
2011 Kona Blue's Avatar
2011 3.7 currently 34k plus miles. Passenger side front O2 sensor went bad.
I do have headers and off road x pipe.
Zero other issues
Old Mar 23, 2014 | 06:55 AM
F.D. Sako's Avatar
2013 Boss with little less than 20k.
So far I've had to get the engine bay paint fixed due to paint chipping under master cylinder, and I just went to the dealer to start a warranty claim for the radio screen. It started cracking about 5k miles ago.
Old Mar 23, 2014 | 09:54 AM
MKMotorsport's Avatar
Wayne
What is the recommended 1st drain/service for the rear diff under normal usage?
When I dropped the factory cover @ 23.5k to replace with the Boss cover, my fluid was low and looked miserable. The fill plug magnet had several mm deep of ferrous fine metal paste on it.
I forgot to mention I have had my radio display changed under warranty.
Things that I know are wrong that I need to bring to Ford's attention:
-Paint bubbling under hood.
-Front control arm or maybe strut bearing noise at very very low speeds only.
-Convertible top latches vibrate annoyingly under certain conditions.
Old Mar 23, 2014 | 11:48 AM
wanted33's Avatar
Z, it's like wheelman says. Not a big deal to fix, and it's just something that came with the car. But, the things look like crap when they start to fall apart. And they are a great conversation starter.
wheelman, thanks for that information. I'm heading to the dealer tomorrow so they can order me a couple more.
Old Mar 23, 2014 | 12:59 PM
mac951's Avatar
Recently started getting a rattle on the dash but only when the car is cold. Can't for the life of me find it yet.
Other than the control arm squeak that was fixed under warranty everything has been great so far.
Old Mar 23, 2014 | 05:22 PM
FordIVTteam's Avatar
Ford In-Vehicle Technology Rep
Originally Posted by UOP Shadow
2013 GT500
Hi UOP Shadow,
Make sure you're running the latest software: www.Support.Ford.com
Let me know if I can help with anything.
Hey DarrenGT,
Is there anything specific going on with your SYNC system?
Kim
Old Mar 24, 2014 | 03:03 AM
conv_stang's Avatar
Originally Posted by FordIVTteam
Hi UOP Shadow,
Hey DarrenGT,
Kim
Would help if every time you try to register at that site it didn't give you an "I'm sorry, something went wrong error"
Old Mar 24, 2014 | 07:06 AM
2012GT's Avatar
Drove me nuts too
Old Mar 24, 2014 | 01:39 PM
mac951's Avatar
Originally Posted by 2012GT
Drove me nuts too
did you get it fixed? If so what was it?
Old Mar 24, 2014 | 03:08 PM
Hi conv_stang,
Try clearing your history and attempting the registration process again at: www.Support.Ford.com
If you receive a message indicating that the username has already been taken, please let me know.
If you would like me to create the account for you, send me a PM with your name, VIN, mobile phone number, and address.
update: Right after I responded to your post, I received confirmation that some users are receiving the following error message: "We're sorry. We experienced a system error while processing your request." The issue has been reported and support is working on getting this resolved as soon as possible.
Kim
Old Mar 25, 2014 | 11:45 PM
DarrenGT's Avatar
Hi UOP Shadow,
Hey DarrenGT,
Kim
it is having trouble automagically connecting to my galaxy every time i get in. It used to. I use bluetooth audio all the time, but the phone feature doesn't always connect.
Old Mar 26, 2014 | 12:02 AM
  #40
2014GHIGGT's Avatar
2013 GT500
I have had many sync vehicles. F-150's, fusions, edge, Taurus, mustang, etc. during this time I ran into similar issues and I figured out one common denominator every time I experienced a sync issue forcing me to pull the sync fuse and force a hard reboot of the system. Each time it was caused by what I believe was me overloading he system. I'll explain. I use an iPhone and use iCloud to sync all of my music in the cloud. It's a massive amount of music and I like being able to access all of it any time I want. I noticed that when sync would freak out so to speak the show all music and iTunes Match functionality was turned on. When I only had music that was physically on my phone active I had no issues. For some reason I do not believe sync likes the iTunes Match feature. If using an iPhone I recommend pulling your sync fuse to force a hard reboot, and turn off the iTunes Match feature prior to getting in your car each time. It's helped me a ton and I now have much fewer issues.
I believe the iTunes Match feature makes the phone appear as if it has a new profile each time and sync tries to create a new sync image each time. Then sooner or later it runs out of memory and acts nuts as you describe.
