Check engine light
Old Apr 2, 2012 | 09:07 PM
kevinsworld3's Avatar
Check engine light
I have a 2010 GT and my check engine light just came on....there are 6000 kms on the car all fluids are topped....the dealership I bought the car (Chrysler) did an oil change just before I drove it home....I noticed the oil temp was a little on the hot side could that cause a check engine light to come on...or any other suggestions ?
If they put the wrong oil in might that do something, car runs great
Old Apr 2, 2012 | 09:10 PM
07S197's Avatar
Swamp Donkey Man Cans
Oil Temp? It wouldn't have an oil temp gauge. Should be water temp, oil pressure, batt voltage and fuel.
I would take it back to the dealer and have them check the code. Could be something very simple.
Old Apr 2, 2012 | 09:15 PM
That's not oil temp? It has a oil can and then C at one side and H at the other....I'll probably take it to the dealer still full warranty on it....I was just curious if someone else out the had some insight
And thanks
Old Apr 2, 2012 | 09:21 PM
07S197's Avatar
Top left is fuel level
Top right is engine temp
Bottom left is battery voltage
Bottom right is oil pressure.
Old Apr 3, 2012 | 03:41 AM
Sorry pal your right I thought it hot and cold .......well then the oil pressure was a little on the high side......it's my first mustang and then the check engine light comes on so I was searching for an explanation.....I'll take it to the dealership today
Old Apr 3, 2012 | 05:54 AM
07S197's Avatar
Yeah the oil pressure on mine runs on the higher side of normal too.
Old Apr 3, 2012 | 06:30 AM
Ok good....just going through the process of elimination taking to dealer tomorrow thanks
Old Apr 3, 2012 | 10:49 AM
stupidgenius36's Avatar
Just Plain Rude!
Well just a heads up, the battery and oil pressure gauges are pretty much worthless. Anything in the middle or just a bit high is normal. If you ever have a problem, it'll suddenly go waaay high or waaay low. But by then, it's too late.
Ecostang
Nov 3, 2022 08:50 PM
STOERKEL
Sep 11, 2015 11:38 AM
ClayP
Aug 11, 2015 06:23 AM
Will3212
Jul 16, 2015 10:30 AM
