Bushings for Steeda UCA and swaybars
Old Sep 5, 2017 | 08:00 AM
trackpack13gt's Avatar
So I just purchased the steeda lca and sway bars.
Is there a polyurethane bushing available for the pumpkin where the uca attached to? If so which is the one to get.
Also adjustable sway bars front and rear. It's unclear if steeda actually sell these from looking at their current selection online. Ideas appreciated.
Old Sep 5, 2017 | 05:39 PM
So I have located the steeda uca bushing to the pumpkin. It looks like the metal cup the factory bushing comes in must be reused. So somehow removal without damaging the cup will have to take place.
I also think based on the single front or rear sway bars, the bushings and bracket come with the kit. The front and rear sway bar page does not show any bushings listed.
TJ can you please elaborate. Many thanks.
Old Sep 5, 2017 | 06:18 PM
5.M0NSTER's Avatar
The front bar came with bushings. I'm sure the rear does also.
Old Sep 5, 2017 | 07:10 PM
Bert's Avatar
I thought everything came with the needed bushings.
I'm a little surprised that the rear UCA did not have all the bushings included; I guess this was probably the case with mine also but I did not notice because a shop did the install so they must have re-used the old one.
Old Sep 5, 2017 | 07:36 PM
EF1's Avatar
EF1
I have the Steeds competition adj sway bars front and rear. The rear came with the new end links and bushings. The front came with the bushings that mount the bar to the radiator support, but no end links. I am still using the stock front end links. I haven't decided if I want to go adjustable or not.
