Brembo Wheel Tires?
Brembo Wheel Tires?
If you have replaced your OE tires on your BBP wheels, what tire size did you replace them with? Instead of 255/40/19, I was considering either 275/35/19 or 275/40/19... I was wondering if rubbing would be an issue, as I'm running Steeda UltraLite springs in my car.
Thanks for all your help.
The 275/35/19 is 0.46" shorter than stock while the 275/40/19 is 0.63" taller than stock. Width should not be an issue for rubbing as I'm running 285's on all four corners on street tires and 295's on race tires with no rubbing (though the 295's are close).
