Brembo Wheel Tires?
Old Aug 23, 2011 | 10:37 AM
2011 GT's Avatar
Brembo Wheel Tires?
If you have replaced your OE tires on your BBP wheels, what tire size did you replace them with? Instead of 255/40/19, I was considering either 275/35/19 or 275/40/19... I was wondering if rubbing would be an issue, as I'm running Steeda UltraLite springs in my car.
Thanks for all your help.
Old Aug 23, 2011 | 02:15 PM
jsnyng's Avatar
The 275/35/19 is 0.46" shorter than stock while the 275/40/19 is 0.63" taller than stock. Width should not be an issue for rubbing as I'm running 285's on all four corners on street tires and 295's on race tires with no rubbing (though the 295's are close).
Old Aug 23, 2011 | 03:36 PM
Overboost's Avatar
I went with the stock tire size. When I finally decide to upgrade wheels down the road, I will most likely go with a 10"+ wide rear tire.
lowblustang00
Sep 5, 2015 12:18 PM
robjh22
'10-14 Exterior Modifications
Aug 12, 2015 02:13 PM
