Brembo / Track Pack Spare Tire Summary and Question
Hi everyone!
I apologize in advance for the long post. At the risk of beating an equine past its natural expiration date, I'd like to clarify options for spare tires on the Brembo / Track Pack GTs.
To summarize the problem, the Brembo / Track Pack cars come with a tire mobility kit (also called a temporary mobility kit) instead of a mini spare tire. Some motorists who live in or travel through rural areas are uncomfortable with the level of security the mobility kit provides.
The problem is compounded by the fact that the 17" aluminum mini spare that comes with the GT will not clear the Brembo brakes in the front. Moreover, though it fits on the back, some have voiced concern that the mini spare should not be installed on the rear either because the overall diameter is approximately 1" smaller than the full size tire and this can cause undue wear to the Torsen differential (due to heat and lubricant breakdown) or locking differential (due to undue wear on the internal clutch).
The best (admittedly a pretty good) solution I've seen so far is to obtain a Drag DR-34 or DR-50 18x7 wheel and install a 225/50/18 tire, which will give a "full size" spare that clears the Brembos in the front and has a similar overall diameter to the other wheels and thus can be installed without fear on the rears as well. The only drawback is that when stowed the tire will stick out of the wheel well approximately 1.5".
In addition to my Track Pack GT, I also have an S2000 (at least for the time being). The S2000 has a Torsen differential and a mini spare that also doesn't match the overall diameter of the other tires. The driver is advised to replace only the FRONT tire with the mini spare. If the flat is on the rear, the driver should install the mini spare on the front and replace the flat rear tire with the good front tire. I would also be okay with this setup for the GT in a pinch (i.e., if I had a blowout far from civilization), if I could just find a compact spare that would clear the Brembos.
So my question is: Is it possible to also solve this problem with a narrower wheel (presumably 1-1.5" narrower), wheel offset, and / or wheel spacers? Also if anyone has measurements on the aluminum GT spare that might be helpful to me or others who don't want to give up on the compact spare idea.
Thanks for sticking with me on this long post, and any info to move toward a working compact spare would be appreciated.
I know it will probably be an expensive spare tire but I was wondering if one of the those weld drag racing skinny wheels or another brand would fit in the wheel well. I know they definately wouldnt stick out and they make ones that clear the brembos.
I plan on picking up one 17" SVE drag wheel and front skinny tire from Late Model Resto to use as my mini spare. If I have a flat on the back, I'll switch a front tire to the rear and put the spare on the front.
Keep in mind the spare well is 8.5 deep and 27.5 across (assuming its the same as 08's).
If it sticks up a bit (like my Marauder mini does) just put a 1/4" piece of plywood over it and cover it with the carpet. Looks fine and I'm able to fill the trunk with coolers, suitcase, etc just fine on trips. The weight is minimal and if you're going to be doing something where weight matters, just take it all out for that day.
Got this wheel: http://www.americanmuscle.com/black-amr-18x8-0513.html
I fitted a 225/50R18 tire to this wheel and it fits in the trunk space just fine. Just an FYI: If your mustang is lowered make sure you get a jack that is lower than 4 inches when compressed so it will fit under the side skirts with a flat tire.
http://www.torsen.com/products/T-2.htm
This is a good idea I didn't think of. I noticed the 4.5" rim says "drag racing only." Do we think this can hold up to highway use (rocks and stuff)?
The Torsen T-2 differential is mini-spare compatible:
Also, I was wondering if anyone has tried the 17" OEM aluminum spare with a spacer? Or do you need the 18" diameter to clear the Brembos?
Also, people with a solution, did you buy a Ford jack and bracket, or what are you using?
I don't see why the drag skinnies couldn't be used on the freeway - they're street legal tires. Obviously having the spare on the car isn't ideal, whether it's a dedicated "mini spare donut," a mismatched narrow tire on an 18" AMR, or a drag wheel. I figured I'd have a little fun with my spare lol
I prefer a jack with a nut on the end that I use a speed wrench on. I carry that and a breaker bar (instead of a 4 way) in my kit.
![](http://ecx.images-amazon.com/images/I/21KorugticL._AA160_.jpg)
The Boss 302 and Track Pack GTs have a T-2 style Torsen:
http://www.torsen.com/files/Ford%20M...2%20Torsen.pdf
I would still treat it like a temporary spare and stick to the 50mph/50mi rule. You need a full size spare if you want more capability than that. The Boss 302 and Track Pack GTs have a T-2 style Torsen: http://www.torsen.com/files/Ford%20M...2%20Torsen.pdf
![Banghead](https://themustangsource.com/forums/images/smilies/banghead.gif)
I think the drag skinnies would be fine on the freeway. I've seen plenty of cars drive to the track and home on skinnies.
Oh, now I understand. You'd have three of the front wheels, and your spare would essentially be a matching full size spare. Pretty cool idea.
Exactly lol. Obviously the track is a but different than a bumpy freeway, but it should be fine.
On my previous ride, I ran around town with 20's and a seriously crazy drop for around 2-3 years. Didn't have a donut in the back either. I had a flat once, and simply called the roadside service. No big deal, just an extra 30 mins of your life that you'll lose. Now, I wouldn't think about going on a long trip without a spare...so I guess the Coyote will be staying near home base for the rest of the foreseeable future...no biggie!! BTW...it was a GS430.
![Brembo / Track Pack Spare Tire Summary and Question-img00020-20110114-1726.jpg](https://themustangsource.com/forums/attachments/f726/159513d1458686517t-brembo-track-pack-spare-tire-summary-question-img00020-20110114-1726.jpg)
Looks like I'll be making a spare. Walked out from work this morning... 1600 miles on it. Completely flat.
I used the mobility kit, it worked - took it to the dealer and they didn't change out the pressure monitor or anything. Is it going to need replaced?
![](https://scontent-a-ord.xx.fbcdn.net/hphotos-xaf1/t1.0-9/10366129_10152236504429151_2556111586335942378_n.jpg)
