Brembo car will be faster
Old Apr 15, 2010 | 11:52 AM
2K3 Mach's Avatar
If this has been discussed, pls delete.
The overall diameter on the P255/40R19 Brembo tire is 27.0"
The overall diameter on the P245/45R19 GT and GT/CS is 27.7"
According to my calcs, that's about 2.55% bigger than the Brembos. Taller tire lowers the overall final drive ratio, blah blah....
Is it safe to say that it would be like only having a 3.63 axle ratio? (3.73 minus 2.55%)
Old Apr 15, 2010 | 12:11 PM
jedikd's Avatar
Not accounting for the higher unsprung mass of the larger brakes/wheels/tires.
Old Apr 15, 2010 | 12:31 PM
2K3 Mach's Avatar
True! That's why I floated this out there...
I would think the Brembo wheels may be lighter.
Old Apr 15, 2010 | 12:32 PM
Ltngdrvr's Avatar
I'm sure the straight line performance difference will be marginal.
Old Apr 15, 2010 | 01:13 PM
Dave07997S's Avatar
As far as weight goes it will probably be close to a wash. The Brembo wheels aren't light at all they weigh in at close to 30lbs and the smaller (width) 19X8.5 wheel may come in a few lbs lighter than this. However, the tires on the Brembo car weigh in at 27lbs, while the 245's weigh in at 31lbs!! Yikes..my 305/30/19 on the back of my Carrera weigh less than that at 30lbs. As far as the diameter is concerned may make a slight difference but one that I think most people won't notice..other than the better ride over the Brembo equipped car.
Dave
Old Apr 15, 2010 | 01:15 PM
DontShoot's Avatar
According to my calculations, a car with NO brakes will go faster.
Old Apr 15, 2010 | 01:41 PM
jedikd's Avatar
Haha wrong, the Toyota will be the fastest!
Old Apr 15, 2010 | 06:16 PM
blksn8k's Avatar
As far as weight is concerned it is probably a wash even if the Brembo package wheels are lighter. I would expect the larger 14" Brembo rotors to be heavier than the stock rotors. It is all rotating, unsprung weight.
jim010
31
Sep 14, 2015 08:39 PM
JCStang
Aug 1, 2015 05:50 AM
Jul 30, 2015 06:47 AM
Coyote5-0
Jul 17, 2015 03:47 PM
Rodsmustang
Which is Better
Jul 14, 2015 02:09 PM
