Black Track Pack Wheel question
Old Aug 11, 2011 | 06:43 PM
2011 GT's Avatar
Does anyone have some pics of the FRPP Black Track Pack wheels installed on their (dark colored) 5.0? And what would be the largest size tires you could run on them... 275's? Thanks in advanced for your help!
Old Aug 11, 2011 | 09:07 PM
99mstng's Avatar
I would do 275 35 19's all the way around so you could rotate them. 285 on a 9" rim is pushing it and lowered in the front you may rub . . .
Old Aug 11, 2011 | 10:15 PM
Stick's Avatar
275s up front on my V6 rubbed on full turn. They are now on my GT and do not rub, but they could have been worn down enough from the V6. I'm just not sure.
Old Aug 11, 2011 | 11:55 PM
Hytek's Avatar
http://www.cjponyparts.com/ford-raci...5-2011/p/W101/
If these are the same, then yes you can run 275's all around.
Old Aug 12, 2011 | 09:01 AM
99mstng's Avatar
I see you are running the Nitto's 275 all the way around. How do you rate the grip compared to the stock rubber?
Old Aug 12, 2011 | 11:45 AM
Hytek's Avatar
On dry they are awesome. Cornering is great, I can take the on/off ramps quickly without worrying. There's a little bit of road noise but I hardly hear it with the Roush exhaust. Wet conditions, not so much. But my stockers were the 18" Pirelli's so they're going to be better in wet conditions anyways.
Old Aug 14, 2011 | 12:18 AM
Stangpilot007's Avatar
Steeda Ultra Lite's are a 1.5 inch drop? I would say you will definitely be risking rubbing if that's the case. I read that Shaun (Stinger1982) had to roll his front fenders because he had rubbing with his RTR's which too had 275's on the front and back. His car is lowered with FRPP K springs which is also a 1.5 inch drop.
Old Aug 15, 2011 | 01:21 PM
2011 GT's Avatar
Hatch... Yes, those are the exact wheels.
Still not sure about wheels, but I'll have to make a decision soon
SickShade14
Sep 26, 2020 02:45 PM
salazamk
Aug 22, 2015 02:19 PM
