The Beauty of keeping it Stock...
Old Oct 11, 2013 | 03:29 PM
Black Fire's Avatar
MGW and GT500 Axlebacks here otherwise stock as can be.
Old Oct 11, 2013 | 04:12 PM
Ltngdrvr's Avatar
Yup, no skip shift on '13-'14 cars.
Mine is basically stock so far(hood struts, shift ****) but I will be replacing the rear control arms to get rid of the axle tramp at the strip and I may some day do a tune to raise the rev limit. Pretty satisfied with the HP/TQ as it is though.
Old Oct 11, 2013 | 06:20 PM
jmaStang's Avatar
I have the MGW, GT500 ABs, and JLT oil separator. Waiting to go in are Eibach shocks, struts, springs, and sway bars. I will probably get wheels, tires, and a grille after that.
I will consider my car "pretty much stock" until I pull the trigger on intake, tune, and Boss mani. Really trying to hold off on that order for awhile.
Old Oct 11, 2013 | 09:19 PM
rick57's Avatar
mine will be stock except for protection things like seat covers ,clear bra mats, sterring wheel cover.
except im going to put chrome rims on it hate the pp ones
Old Oct 11, 2013 | 11:45 PM
MJJ's Avatar
MJJ
My DD truck is stock .
Both Mustangs are heavily modified. Strongly considering adding a 3rd fun car. If I do it will remain stock! Granted stock is still amazing so it's not a real sacrifice.
Too **** expensive to risk warranty issues.
Old Oct 13, 2013 | 07:20 AM
sclv12's Avatar
Originally Posted by dmichaels
No, 2013 & 2014's do not have skipshift. Confirmed by Ford Rep (scroll to post #10): Skip Shift Thread I can verify I have shifted from 1-2 thousands of times by now at all different RPM's and speeds (as low as 1000 rpm or so if I'm rolling up to a stop sign and everywhere in between that and redline) and have never, ever had anything resembling skip shift force me or try to force me to do a 1-4 gear change. Maybe you got a leftover 2012 MT82??
Originally Posted by Charlie_santos
Lmao! Heres the picture I used. Its easier to get to with a lift but jack stands will do. I did mine on a lift and my buddies on stands http://www.svtperformance.com/forums...ding-tune.html
Well, I disconnected this solenoid and now I don't hear plates moving when pushing in clutch at under 3000 in first and it doesn't grind and clunk going into 2nd. I doubt I have a 2012 trans on a 2014 built in August 2013. I think this is a feature that returned in 2014 models. I just wish ford would be more forthcoming with this mine definitely has it. When I would shift from 1-2 under 3 k it grinder clunk going into gear and the was with clutch to floor and off gas. At higher rpm it was smooth. Now that the solenoid is disc so is prob.
I have 14 GT TP what do u have?
Old Oct 13, 2013 | 07:27 PM
jmaStang's Avatar
Old Oct 13, 2013 | 08:27 PM
dmichaels's Avatar
2014 base GT track pack. Build date may, 2013. Mine absolutely does not have skip shift. If it did, I would remove immediately.
Old Oct 13, 2013 | 10:34 PM
elkk's Avatar
I have a 2014 base GT, I do not have skip shift and I am certain 2014's do not have it. Not sure what you unplugged but??? The picture post you referred to is from 2010.
Old Oct 14, 2013 | 04:51 AM
EastTNMustang's Avatar
Well, I disconnected this solenoid and now I don't hear plates moving when pushing in clutch at under 3000 in first and it doesn't grind and clunk going into 2nd. I doubt I have a 2012 trans on a 2014 built in August 2013. I think this is a feature that returned in 2014 models. I just wish ford would be more forthcoming with this mine definitely has it. When I would shift from 1-2 under 3 k it grinder clunk going into gear and the was with clutch to floor and off gas. At higher rpm it was smooth. Now that the solenoid is disc so is prob. I have 14 GT TP what do u have?
So does he have skip-shift or a bad transmission/car?
Old Oct 14, 2013 | 05:41 AM
Nighthawk13's Avatar
Originally Posted by FromZto5
Yes mine's all stock.
My CS is more stock than yours Z.
Old Oct 14, 2013 | 06:06 AM
Bucko's Avatar
Until you install that first tune...then you'll ask yourself why you waited so long, other than warranty issues perhaps.
Old Oct 14, 2013 | 09:35 AM
sclv12's Avatar
I don't want to keep arguing about this cause that's not what this thread was for but on another forum they had same discussion so here is a link to it check out page 13....
https://docs.google.com/viewer?a=v&p...mYxMzZmNjk2ZDk
Old Oct 14, 2013 | 10:13 AM
LOL Phil... you caught me. Guilty as charged
In regards to the skip shift discussion, I never had that, even tho mine's a 12.
Old Oct 14, 2013 | 03:38 PM
elkk's Avatar
Do have happen to know the link for 2014? OP has a 2014, they apparently had skip shift in 2013
Old Oct 14, 2013 | 04:45 PM
sclv12's Avatar
Right and the cars are the same
Old Oct 14, 2013 | 04:52 PM
Goatdad's Avatar
I'm completely satisfied with my stock 13 GT. Doesn't mean I wont be modding soon but I'm cumming from a C6 that ran 12.6's when stock and this thing just pulled off a 12.6 bone stock (power wise,I have springs and axle back)!!
Old Oct 14, 2013 | 04:53 PM
sclv12's Avatar
I don't blame people for saying they don't have it cause it is possible some of these cars might not have it. But, it is true that some do cause many guys have complained about the same symptoms about shifting from 1-2. I just wish that ford would tell you if the car has and allow for it to be shut off without unplugging the connection underneath. Also, some might have it and not realize cause when u shift over 3 k it doesn't activate the skip. There also could be other factors that turn it off, but since I unplugged it I can't test what might turn it off.
Old Oct 14, 2013 | 05:11 PM
dmichaels's Avatar
Can check the tranny for the solenoid on the tranny... probably the sure fire way to check. I haven't looked at my tranny for the solenoid connector, but there is no functioning skip shift on my car.
Wonder if they built some 2013/2014's with "leftover" trannies that contained the skip shift? Might help explain why some have more tranny issues than others - if they worked out some of the bugs in the later production run MT82's (without skip shift?) they may tend to work better. I have had almost no shifting issues at all thus far...
Old Oct 15, 2013 | 05:03 PM
  #40
jmaStang's Avatar
I thought I already posted this, but I don't see it.
A notchy 1-2 is not skip shift.
