Battery Done...Can you believe it????
Old Sep 27, 2015 | 01:23 AM
lakersfreak's Avatar
Battery completed dead after just 2 years! Same thing happened to my wife's Edge after 2 year. Does Ford install crappy batteries or what!
Luckily I had AAA and they quickly came and replaced the battery for me. If I wasn't on vacation 200 miles away from home then perhaps I could've replaced the battery myself. Turns out AAA was cheaper anyhow, who knew...
Old Sep 27, 2015 | 12:48 PM
=HYPERDRIVE='s Avatar
My battery isn't completely dead, but after 3.5 years its life has shortened. Went to a drive-in cinema this summer and 30 minutes into the movie, I could not start my car up, had to have it jumped, and let it run for the rest of the movie. It works fine, but I dont charge or let any electrical things run when the car is shot down.
Old Sep 27, 2015 | 01:15 PM
SpectreH's Avatar
Why not go ahead and replace it before it strands you?
Old Sep 27, 2015 | 06:33 PM
GT50GO's Avatar
I hear you, my factory battery lasted a whole year & 10 months then failed. I replaced it with a AC Delco Pro 96RP and so far it's been fine.
Old Sep 27, 2015 | 06:36 PM
Cdvision's Avatar
The battery in my GT500 is 6 years old...never any problems.
Old Sep 27, 2015 | 08:10 PM
Siber Express's Avatar
My Battery is 3 years old, been run down once to nothing and still starts fine. 2000 Explorer was 9 years old and 200,000 miles before it was replaced so there are a few good ones out there.
Old Sep 27, 2015 | 09:53 PM
chronos's Avatar
My battery lasted me for 6.5 years before it died. Can't complain. On my Dodge Ram though it only lasted me 2 years when that was new. I think it's a luck of the draw. Hehehe, draw, get it? As in current. I'm so clever I amaze even myself.
Old Sep 28, 2015 | 06:34 AM
stupidgenius36's Avatar
Just Plain Rude!
I have to change my alternator every two years, and my battery every 2 or 4 also (depending on if the alternator takes the battery out with it). So I figure you're doing alright...
Old Sep 28, 2015 | 01:28 PM
VIP1's Avatar
You shouldn't need to replace your alternator and battery every 2yrs. Something is either wrong or you are drawing too much current. Do you have a custom stereo setup?
Old Sep 28, 2015 | 02:46 PM
Just Plain Rude!
Nope, it's been like that since day one. Common problem with early S197''s. I would think they've got it figured out by now, but who knows. You'd think they know how to paint aluminium hoods by now too, but...
Old Sep 28, 2015 | 10:43 PM
TheReaper's Avatar
Ford will give you a new one if you are still in warranty.
Old Apr 16, 2022 | 06:39 PM
Falcoony's Avatar
You think we get a charge out of your humor?
You
You think we get a charge out of your humor? So you amaze one person...... We all do....
Old Apr 17, 2022 | 10:55 PM
shaneyusa's Avatar
I am concerned since my original OEM battery went out after around 4 1/2 years, Seems kind of quick. This fall my car will be 9 years old. The replacement battery back in the summer of 2018 was not a Ford battery, but still a good old fashioned lead acid battery. So I am wondering if this one will have a longer life than its predecessor. I did get a different battery charger after I replaced the first battery. Now using a CTek charger and hoping for longer lasting battery life. We will see.
It is really difficult to handle when my Jeep Grand Cherokees (yes I have 2, a 2012, and a 2017) came stock with an AGM battery. My 2012 is coming up on 10 years old and still has the original OEM battery. According to the Jeep Forum this is very common and most 2011 and newer JGCs still are on the original OEM battery. Fingers cross for all my cars life giving batteries. Like them to last forever, hahaha.
Really would like to find a good brand AGM that will fit the Mustang at a reasonable cost. I still have not been able to find a replacement AGM that fits the stock OEM location. I assume they are out there and will look again when this one fails.
Happy trails and wish you all a long and healthy battery life.
Old Apr 18, 2022 | 08:23 AM
houtex's Avatar
I've had an AGM and it's not any better. It's not typically the battery itself, it's the way the system is. And to that, it's about The Amelioration:
https://themustangsource.com/forums/...4/#post6917899
And starting it more times than not. But not a lot wanna do that stuff. I fully understand. It wasn't fun for me either.
Long story short: accept the battery thing. Buy them at Walmart or wherever's cheapest and stop worryin' about it. Do The Amelioration and give it its best chance to not be a problem.
I've been doing that with Awesome and haven't had any complaint, except the fact I let her sit waaaaay too long between starts one time and that meant new battery... and another Wally Worl trip. I'm better about the starting now.
Old Apr 18, 2022 | 11:02 AM
m05fastbackGT's Avatar
Exactly well said! Doesn't matter what type of batteries are used, it's the non-stop milliamp draw of the computer/electrical system a.k.a keep alive memory of the pcm modules which are responsible for draining batteries if they sit for too long.. The only real solutions is either disconnect the battery if the vehicle is not being used for long periods or connect the battery to a battery tender.. Since using a battery tender, my Motorcraft batteries have lasted up to 5+ years.. Prior to that, I had to replace 3 batteries in less than 2 years..
Old Apr 18, 2022 | 07:32 PM
mustangGT90210's Avatar
I will buy Jack Stands!!!
Down here in Florida, you're lucky to see a battery last 3 years on a modern vehicle. And that's on a modern daily driver. I've squeezed 4 years out of a daily driver before, but it was a '94 F150, with many less electrical draws than todays vehicles
Old Apr 18, 2022 | 08:27 PM
shaneyusa's Avatar
Ok I do understand what you guys are putting down, but there is part of it that is flat out has to be wrong.
My Mustang sits for 3-4 months each year. The battery is always disconnected for that time. While disconnected I drop a charger on it every 3-5 weeks, before the new CTek charger It was always on the trickle charge setting. When it is connected it rarely sits for more than a week, maybe 10 days without getting driven.
Now the Wife's 2012 JGC was bought new and is a month away from being 10 years old. The vehicle has 49K miles on it, super low mileage. So she is averaging a little over 400 miles a month, but it is not driven every month. I know periods when she was staying in our vacation home for a month or more usually two times a year that the vehicle was not driven or charged. Her battery has been amazing and is still going strong.
There has to be a difference between the (not-so) good old fashion lead acid battery and an AGM style battery. I know the AGM format is more $$. They are also supposed to handle discharge better. The battery in her JGC is the first AGM I have had, and 10 years is pretty frick'n amazing. Now your @houtex reference to the Red Top Optima in the linked post, shows that a well built AGM battery, which is what the Red Tops were back when you wrote that, does make a difference. It is hard to believe that all those Jeep owners with the AGM batteries are just lucky and/or got a good one and/or maybe just know the perfect amount of starting it takes to keep it perfectly charged.
I am a big believer in you get what you pay for. I have used Wally World batteries and they really are poor. Also I realize there are only a small number of battery manufacturers for Lead Acid Batteries (sounds like mostly made in China). Seems like they just don't or can't build them like the use to. Use to be able to get 6 to 7 years out of one before it gave me trouble. Then you could limp along for a while before you had to replace it. But with today's car battery demands they really don't give you trouble, they just quit, go dead out of the blue. Heard that story way too many times. So I think depending on the life of current battery in my Stang, the next round I may look into an AGM, We will see what happens.
Old Apr 19, 2022 | 06:04 PM
I've never tried using an AGM battery, therefore, I can't really confirm nor deny if they handle battery discharge any better over lead acid batteries.. All I know is through my 17 year experience as a S197 Mustang owner, is ever since I've been connecting my motorcraft batteries to a battery tender, the batteries have lasted for at least up to 5 years with no discharge related issues!
Old Apr 20, 2022 | 10:20 AM
houtex's Avatar
I don't doubt you've had issues, but I've used them and had no issues that weren't my own fault. They're made by Johnson Controls, or whoever they are now, starts with an E, and they're they *exact same* as any other battery you'd fine just like it by Johnson Controls/whatever, including Motorcraft, Die Hard, etc, ad nauseam. Only ones that'd be any different, and not much, would be the other manufacturers. It's not a 'Wally' thing at all. I done the research, I've used the products, it literally doesn't matter which one you use, the technology hasn't changed in decades now, and it ain't gonna, not when it comes to these wet lead acid types.
That said, you absolutely can spend more on the competition, get the same battery, and the same disappointment, if that makes you feel better or something. I ain't gonna sway ya. I just want everyone to know the score on these things: They all the same. Doesn't matter where you buy it, and the others that are higher for the 'same-ish' battery are just marking it up for the *same* battery. 750 CCA is 750 CCA in a 24F, and the label is the change. I want platinum labels for the O'Reilly ones as much more they cost for the same battery as Wally's.
For what all that's worth. Y'all do y'all. Buy the batteries that make ya feel right. That'll do just fine. Don't mind me and my cheap-(donkey) self regarding these things, for I'm quite the idiot, surely.
As to what's killing these things, it's kinda simple:
Car continuous draw will kill it. Period. Eventually or very soon, but that's a thing.
Dirty battery shorting the terminals will cause a similar draw. Keep the battery clean, problem solved.
Goofy alternator overcharging the battery because it's broken and not regulating correctly. Car *should* report it in the newer ones, but older ones...
Cold. Put simply, too cold will kill the thing. Don't let it get too cold. Above freezing certainly, but even more than that.
Hot. Put simply, too hot will kill the thing. Don't let it get too hot. Below boiling certainly, but even more than that.
This last is problematic in the S197s and up, as they stuck the battery behind the strut tower and gave it little air to breathe. That and the headers are right under it, and all that heat just sits there and soaks the battery. You can put a blanket around it, stick it in a box, whatever... and all that means that when the heat gets in (and it will), it STAYS there and bakes that battery.
Take steps to avoid all that and your battery will be better off.
Now, ladies and gents, I had previous to my Awesome a 1997 Ford HoopTBird. It had the original alternator and original battery in it, I would suppose. Neither had ever been changed to my knowledge before I got it. It's possible the alternator had, I just don't know for sure, but that battery was the original Motorcraft one dated correctly. Made by Johnson Controls, as it happens. And so it is that one day the charging system was messed up. Thought it was the battery. Battery tested fine. Removed alternator, had it checked, yep, dead. Got the new one, installed, done. That was it for the charging system, no other complaints since.
When I traded that trooper, although quite not great, car in for Awesome, which was in 2008, or 11 years (possibly 12) of service, *that same original battery was in it* and still functioning.
Why?
It was in the front of the engine compartment, away from the exhaust heat, where it could get air. That's my supposition anyway. All the vehicles that had this mounting up front I've ever had never had batteries swapped out. Awesome? So. Many. Until I did The Amelioration that is, it's been MUCH better. Still that placement is the only real difference between all these vehicles I've owned/used.
Battery placement. It's a thing. Or at least I'm convinced it to be. Heat in the engine compartment... dead batteries. And then all that other stuff I said.
So... um... yeah. There that is.
/Yet another ramblin' dialog by yours truly brought to you by the letter Q, symbol } and the number 5.
Old Apr 20, 2022 | 02:50 PM
At first, I also thought that heat from placing the batteries behind the strut tower was the reason behind them discharging prematurely. However, since connecting the batteries to a battery tender, I have since ruled out the heat issue as the main cause.. During the past 16+ years, all my motorcraft batteries have lasted up to 5 years by keeping the battery connected to a battery tender whenever the car is sitting inside the garage, not being operated.. At any rate, if heat was the main reason for killing the batteries, I wouldn't think connecting a battery tender would make any difference.. Therefore, this leads to my original conclusion, that it's the continuous milliamp draw of the PCM's keep alive memory (K.A.M) which is the mean reason for discharging the batteries. I would however be very curious if anyone on these forums have noticed any differences or improvement by relocating the battery to the trunk compartment
