Axle is leaking
Old Jun 20, 2015 | 05:25 AM
SickShade14's Avatar
Axle is leaking
Hey guy,
So i got underneath my car last night to install my Uca and I've noticed my axle is leaking from the left side of the axle tube. I did some snooping around on some past threads and it was mentioned that the leak maybe coming from an Axle vent cap?
The car only has around 18k on it and I was wondering if i should just take it back to the dealership or is it a quick fix for something such as replacing this Axle vent cap? Also, if i installed my upper control arm do you guys think it would possibly be an issue with the dealership fixing the leak warranty wise?
Old Jun 20, 2015 | 07:28 AM
Blown CS's Avatar
Depending on the dealership, but ford does have a bladder vent they can put on it. http://www.svtperformance.com/forums/showthread.php?775797-Rear-axle-vent-leak-what-is-the-solution
Your control arms shouldn't cause an issue with warranty work.
Old Jun 20, 2015 | 07:48 AM
Awesome, thanks! I've been dying to install my uca for a week now. I'm gonna install it later today and schedule an appointment to drop my car off at the dealership.
Thanks again!
Old Jun 20, 2015 | 04:05 PM
gManTexas's Avatar
Yes, it's venting. You can buy a catch can for it. Google Bob's catch can.
Old Jun 20, 2015 | 06:01 PM
shouldhavegottheGT's Avatar
Could also be the axel bearing seals. Mine were just replaced. All the stuff with the axels and diff fall under the power train warranty. Mine had about 45k when they did it.
Old Jun 22, 2015 | 06:24 AM
Dean Martin's Avatar
I have the bladder mounted on the top of the GT500 differential cover for about a year now with no problems.
I just did it all myself because I had 60K miles and figured a fluid change could not hurt and I really don't like going to the dealer.
Old Jun 23, 2015 | 06:36 AM
JoeMidnight's Avatar
Originally Posted by SickShade14
Hey guy,
This is normal. Mine did the exact same thing. I'm told its normal and will eventually stop (which it did) . Happens when the cars new.
Old Aug 5, 2015 | 07:19 AM
JonsMustang's Avatar
Rear axle? If yes, there's a tsb on that to replace pinion seal on rear axle.
Old Aug 5, 2015 | 09:40 AM
wvtrain's Avatar
I'd look at the Pinion Seal Area, if it's dry, it's not the Pinion Seal. If what you're seeing is mostly on top of the Drivers Side Axle Tube, it's the Vent. There is a Ford TSB, I have a 2013 GT, just took mine to the Dealership last week, they cleaned the Axle Tube, and changed the Vent with a New Type, checked Gear Lube Level, added 1/2 Quart, Plus new Friction Modifier. Job should only take 40 Minutes!
Rando
Aug 25, 2021 11:12 AM
Gill5oh
Oct 6, 2017 10:50 PM
09-gt/cs
Oct 15, 2015 10:03 AM
Rando
Sep 30, 2015 12:28 PM
Sep 24, 2015 08:15 PM
