for anyone who knows headlight installations
Old Mar 11, 2013 | 10:15 PM
dmk3's Avatar
I just installed an HID set of lights in my car and I'm now having issues with my drivers side flasher. The headlights I installed work perfectly fine, but when i press the unlock button on my car both of the flashers come on, but the drivers side one turns off about a second after it lights up. when the headlights are on, the flasher does not light up at all on the driver side while the passenger side stays lit.. When i turn on the directional, the light works fine.. before I retrace my steps with the install can anyone help me out on what might have gotten messed up?
Old Mar 12, 2013 | 08:27 PM
bones302's Avatar
if you installed a set of aftermarket headlights with built in HIDs, it sounds like the issue is with the headlights themselves. If so, sounds like you need to contact the manufacturer. double check how you attached the signal bulb in the socket
JonsMustang
Mar 5, 2016 05:44 PM
CoyotePremium13
Sep 23, 2015 06:45 PM
50Cal
Sep 17, 2015 06:43 PM
Sep 10, 2015 12:44 PM
SMOKE46
Sep 6, 2015 09:40 PM
