AM Modern Billet Polished Grille Combo
Hey everyone! New to this app! Has anyone purchased and installed the Modern Billet Grille from American Muscle (13-14) v6? From what I've read it's quite complicated and there aren't many videos out the for this grille. Any help is much appreciated!
Former Vendor
The Modern Billet Polished Retro Grille Combo is an awesome mod that absolutely transforms the front end of the car.
As long as you are willing to remove the bumper to install the grille, the install is easy as pie!
People run into issues when they try to install the grille without the removal of the bumper and hit some snags along the way.
Check out the Installation Guide as it should shed some light for you!
Hope this helps and let me know if you have any questions!
-Will
I have this grille and installed it by taking the bumper off. All in all it was a pretty simple installation. The hardest part is getting the bumper off. I would recommend that you place something under bumper to support it after you take off all the bolts. I had a hard time trying to hold the bumper up and try to disconnect the temperature sensor and fog light harness at the same time. Same advice for when you put the bumper back on.
9/16/15 06:44 PM
