Almost Acts Like My Old Top Loader
Old May 13, 2020 | 01:33 PM
Siber Express's Avatar
Went out and got the Blowfish Shifter Support Bracket and it shifts better than it has ever shifted. No more hard to get into second under power and the 3rd gear lock out is no more coming out of a corner.
Now to get rid of the Dual Mass Flywheel and I think most of the Quirks that actually bothered me will be gone
Some crappy pics of the Bracket
Old May 13, 2020 | 01:58 PM
Bert's Avatar
wow, that sucker is a lot beefier than I had guessed!
Old May 13, 2020 | 03:02 PM
It is a NHRA Legal driveshaft loop also, but just guessing how far back it needs to be to hold the shifter up it is better to have it over built than replace the ones that get used for any type of racing. On the V6 it needs that rear piece with the bolt in the bottom but it goes in super easy.
Old May 13, 2020 | 05:43 PM
EF1's Avatar
EF1
Are you still running the stock shifter?
Old May 13, 2020 | 05:53 PM
Stock Shifter, I had a Barton Bracket on it.
Old May 13, 2020 | 07:14 PM
EF1's Avatar
EF1
Interesting, I replaced the stock shifter with an MGW (gen 2 I think, not the newer race spec), installed a stainless clutch line and changed to Redline MTL fluid. It solved enough of my shifting problems that I stopped before the Blow Fish bracket. It was next if I still wan't happy but I never thought I needed it. Maybe I should have just done the Blow Fish and save some money on the MGW.
Old May 14, 2020 | 06:04 AM
David Young's Avatar
Looks good Ken, but I have the MADE IN THE USA automatic transmission
Old May 14, 2020 | 06:49 PM
Well I am going to test it out tomorrow, I am going to the Skyway and Dragon.
MGW did not make a shifter for the V6 until 2016 and I was not so much worried about the throw just the lock out.
Old May 14, 2020 | 07:45 PM
EF1's Avatar
EF1
The MGW made a huge difference in my car. Just it and a fluid change and it shifted like butter and no more missed gears. It was like a totally different transmission. Have fun on the Dragon tomorrow. Hopefully it won't be overrun with bikes.
Old May 14, 2020 | 08:22 PM
My buddy in Kentucky has the Older MGW in his 2012 and loves it and now his 2014 V6 has my old Barton Bracket on it, I have not gotten the review on it yet but his wife drives it.
I guess I had better get the Redline for mine, it is time to change the trans fluid again and the MotorCraft with the Additive did not help. I should have changed to the MTL then.
Old May 18, 2020 | 12:17 PM
Well it is definitely an improvement, no more 3rd or 5th gear lock out under power. Shifts like a different car.
Breaking the 1.0 mark on the Accelerometer both left and right without even trying was nice also, the 295's in the rear didn't even talk to me yet.
Old May 19, 2020 | 05:34 PM
houtex's Avatar
So what I'm hearing is get the MGW shifter and the Blowfish bracket and finally, FINALLY enjoy the TR3650 without worryin' so much about gnashing of second or third?
That would be wonderful... so is that right?
Old May 19, 2020 | 06:04 PM
EF1's Avatar
EF1
yes, but our cars have the infamous MT-82 not the TR3650.
Old May 19, 2020 | 08:28 PM
Blowfish does make a Shift Bracket for the TR3650, it helps with the MT-82 so I would think you should get close to the same results.
Old May 20, 2020 | 08:23 PM
houtex's Avatar
Excellent. Positive is good on this one. I'll be gettin' those two next I can. 'Spensive, but sounds like it's well worth the get. Much obliged!
SINBUSTER007
2012-2013 BOSS 302
14
Feb 24, 2019 05:23 AM
Steve@CJPP
Aug 21, 2014 01:19 PM
jaguarking11
Nov 22, 2013 11:10 AM
White5ohh
Jan 9, 2012 12:53 PM
2011GT/CS
Sep 29, 2011 05:11 PM
