View Poll Results: Which tune were you running when cylinder #8 failed on YOUR vehicle?
Lund
0%
BBR
0%
FRPP
0%
Stock!! No tune and #8 failure
0%
I've run multiple tunes and have #8 failure
0%
Voters: 29. You may not vote on this poll
#8 Failures, Which Tune Are You Running?
#42
Yes, the heads are completely new and one of the best designs ever in my opinion for a stock head.---- The block however has taken many charcacteristics from the 4.6/ 5.4 (hence the term modular so the same machines can build different c.i engines with the same machinery for cost effectiveness) . Lower block width dimensions are identical with the 4.6/ 5.0. (Ford saved alot of money here). Bore spacing (not cylinder bore) is identical (100mm or 3.937) with the 4.6, 5.0 and 5.4. Deck height is identical between the 4.6 and 5.0 (227mm). The connecting rod length is also the same with the 4.6 and 5.0 (nothing to do with the block). Crankshaft journal sizes are identical as the 4.6. The aluminum bearing shells are identical to the 4.6. Engine mounts and bellhousing bolt patterns are also identical to the 4.6 (great news for 96-2010 owners). There are many new awesome traits for the 5.0 but to say it is a completely new blue print is incorrect.
#44
Sorry see if you can get to this one...
http://www.trinituner.com/v3/forums/...p?f=2&t=359998
#46
That stuff leaves gunk in your engine...
http://www.s197forum.com/forum/showt...=redline+water
read!!!
read!!!
#47
That Ford was paying attention to cooling the higher compression 5.0 is evident by the oil squirters and the larger oil capacity.
The jury is still out as to the cause or causes.
#48
Sorry if this has already been asked, but as a 6AT owner I'd like to know how many of the tuned #8 failures were in Automatic-equipped cars. I can say 1st hand that my current engine (connected to a 6AT) doesn't get wound nearly as much as I did with my 2011 6MT GT.
In normal driving the auto just upshifts more quickly than I ever would when I was shifting my own gears on the '11, so my hypothesis is that there are very few (if not zero) #8 failures on tuned 6AT cars.
Can someone out there prove me wrong? Maybe this is wishful thinking because i'd REALLY like to quicken the shifts on my 6AT and a proper tune would accomplish that and more.
#49
Like Father...
I ♥ Sausage
I ♥ Sausage
Was just perusing youtube, and came across this..
http://www.youtube.com/watch?v=ohgSb...eature=related
But the next vid that came up of the same car is the one that caught my attention...
http://www.youtube.com/watch?v=RejeR_KMmJI&NR=1
Wonder if it was a N/A or a S/Ced version? I assume S/Ced with that speed, but that would have also been an FRPP S/C and calibration unless it was worked on after it left SAI. Just thought it was interesting and would be curious to know if it was #8 that let go.
#50
#53
I think every tuner is adjusting their tunes. Im sure in the end all tunes will be equal in most aspects. Lund re did my street tune to make is safer. Air Fuel its commanded Widebands it targets and corrects to +-1% of target which is .84 lambda. Spark is Safe. KS is stock.
9/8/15 10:45 AM
