8/16/2010 Powertrain Change?
Old Jun 4, 2010 | 04:43 AM
RedCandy5.0's Avatar
Found this post on AFM
"Was perusing Ford's parts site and looking at transmissions and engines. Apparently there will be a change made on 8/16 to a different version or config of the 5.0 and MT82. Curious..."
Any ideas?
Old Jun 4, 2010 | 05:00 AM
Overboost's Avatar
Interesting. Wonder if there's any truth to this.
Old Jun 4, 2010 | 05:01 AM
I doubt it, but could be that header change that was rumored...
Old Jun 4, 2010 | 05:03 AM
Overboost's Avatar
I highly doubt they'll change the headers , as it was a big selling point for the 2011, and something they showed off a lot. I could see them making a PCM change for the trans, but nothing huge, unless they're seeing high failure rates or a potential problem.
Old Jun 4, 2010 | 05:21 AM
Isn't that comforting.
Overboost's Avatar
Got a link to said post?
Old Jun 4, 2010 | 05:22 AM
http://www.allfordmustangs.com/forum...in-change.html
Old Jun 4, 2010 | 05:34 AM
Stinger1982's Avatar
I am Shauny Clause
MOTM July 2010 Winner
the header thing is BS
Old Jun 4, 2010 | 06:45 AM
I figured as much...wonder what it could be though.
Old Jun 4, 2010 | 06:54 AM
Overboost's Avatar
It's probably a minor change that won't result in any change to the drivability of the car. Like I said before, a PCM calibration or something simple like that.
Old Jun 4, 2010 | 07:04 AM
todd03blown's Avatar
I agree, more than likely just PCM changes to fine tune things even more.
Old Jun 4, 2010 | 07:44 AM
Automagically's Avatar
I could see the PCM changes. Probably a good idea.
Old Jun 4, 2010 | 08:00 AM
fdjizm's Avatar
Probably just a calibration update/small change this is normal, 05-09's had a few...
Old Jun 4, 2010 | 08:12 AM
PTRocks's Avatar
This is a non-exhaustive list based solely on the listings for 5.0L M/T cars at fordparts.com, though there may be some overlap with other models
There is a differentiation for the complete engine assembly, but not for the short block.
Also differentiated for Job 2
Head assy (with valves, less cams)
Camshaft timing gears (Int./Ex.) (Cams aren't changed)
Vapor canister
Steering wheel airbag clock spring
Headlight wiring harness (again, all)
Various wiring harnesses
Starter harness (MT)
Fuse box mount bracket
Base model radio
Back up lamp switch (man. trans.)
Accessory belt tensioner
Engine coolant overflow hose
Engine air box (filter housing)
Engine air box hose (to engine)
Fuel tank sending unit and harness (coupe and convertible)
Fuel feed hose (tank to engine)
ABS control module (for the 2nd time)
Brake splash shield (perf. brakes)
Brake hydraulic lines (rear) - ABS module to firewall
Brake master cylinder
LF and RF brake hoses
Illuminated door sill plates ("Mustang" only)
Door latch striker plate (again)
Brake pedal assy (man and auto) (man for the 2nd time)
Dash pad
Dash panel
Interior Deck mat (coupe)
Front lower interior cowl trim panel (left side)
Air bag module (passenger side only)
A/C evaporator expansion valve
HVAC blend door motor (some models)
Seat cushion valence
Steering rack (for the 2nd time)
Hood insulation pad
Door sill plate (various versions, coupe and convertible)
Interior trunk mat (coupe)
There were also changes to:
The piston cooling nozzles as of April 9th.
Headlight wiring harness on April 19th (w HIDs)
Positive battery cable on April 29th
The PCM as of mid-April (some ambiguity here)
The H-pipe changed May 10th
Headlight wiring harness on May 10th (w halogens)
Steering rack on May 13th
ABS electronic control module on May 13th
Rear Quarter panel molding (convertible) on June 1st
Illuminated door sill plates on June 4th
Audio unit display (all except EC) on June 15th
Front lower control arms on June 16th
Brake pedal assy (MT - metallic trim) on June 17th
Brake pedal assy (MT - standard trim) on June 21st
Seat belts (front - coupe) on July 29th
IUP instrument cluster on June 13th
Door interior trim panel (the hard plastic one) on Aug. 3rd NO LONGER LISTED AS A MOD
Door latch striker plate on Aug. 3rd
Manual transmission - all on Aug. 24th:
- All synchro rings (1-2, 3-4, 5-6, 5th and 6th outer rings, reverse)
- Reverse gear (output shaft)
Cowl side interior trim panel - Stone only - on Sept. 2nd
Floor carpet on Sept. 14th (previously updated March 25)
Old Jun 4, 2010 | 08:14 AM
Overboost's Avatar
Originally Posted by PTRocks
There is a differentiation for the complete engine assembly, but not for the short block. Still digging.
Hmmm...this is also in conjunction with Job 2 (8/16, right?)?
Old Jun 4, 2010 | 08:18 AM
fdjizm's Avatar
ahhh don't change the squirters!
Old Jun 4, 2010 | 08:20 AM
PTRocks's Avatar
Exactly, Job 2 has been mentioned for Aug. 16th.
Old Jun 4, 2010 | 08:31 AM
Overboost's Avatar
Let us know what you can dig up. I'm holding off until Job 2, but if something major is changing and possibly for the worse (which I doubt), I will move my order up sooner.
Old Jun 4, 2010 | 09:31 AM
PTRocks's Avatar
Done digging, see my post above for the list.
Old Jun 4, 2010 | 10:28 AM
Overboost's Avatar
Wow, quite a few minor changes to the car.
