50th Anniversary Wheels Fit on 2014 W/Brembos
Old Feb 1, 2016 | 07:02 PM
RMS70's Avatar
Do the 2015 50th Anniversary Wheels fit over the 4 piston Brembo brakes like on the 2014 GT?
Old Feb 1, 2016 | 08:01 PM
I have a buddy with them, but he's also running 1" spacers front and rear so he has plenty of clearance. Idk if he tried them on without the spacers though. I'll ask...
Old Feb 1, 2016 | 08:02 PM
In case you want to see...
Attached Thumbnails 50th Anniversary Wheels Fit on 2014 W/Brembos-photo622.jpg   50th Anniversary Wheels Fit on 2014 W/Brembos-photo177.jpg
Old Feb 1, 2016 | 08:51 PM
RMS70's Avatar
Thanks for the pictures. Looks better than I thought. I would appreciate you asking your friend about the fitment.
Old Feb 1, 2016 | 09:49 PM
TheReaper's Avatar
A 1" spacer ?
Old Feb 1, 2016 | 11:03 PM
Ah he said they don't fit over the fronts without a spacer...
Old Feb 2, 2016 | 06:24 AM
RMS70's Avatar
That's strange. I thought the 50th Anniversary model came with 6 piston brembo calipers. Maybe the 6 piston calipers are thinner than the 4 piston calipers.
Old Feb 2, 2016 | 11:53 AM
These are the 50th Appearance Package wheels, not the 50th Limited Edition wheels, which are the same dimensions as the 15+ Performance Package. The AP wheels are 19x8.5 and I believe +45 offset.
Old Feb 19, 2016 | 02:46 PM
mfc133's Avatar
Ford reworked the 2015 suspension to have better wheel fitment over large calipers:
http://www.stangtv.com/tech-stories/...n-kenny-brown/
"Ford has said that one of the key advantages with this suspension design is their ability to use larger brake systems without the need for extreme wheel offsets."
I'm guessing no 2015+ wheels will fit over S197 Brembos without spacers...
Old Feb 19, 2016 | 03:03 PM
Bert's Avatar
From the threads I have read on other forums, 2015+ wheels will generally "work" on 2014- cars but they are not the best choice because:
- center bore is larger; so they won't hub-center
- lugs and lug nut taper is different; need to get a set of lug nuts with the old thread and the new taper
- different TPMS system; not compatible (have to buy new sensors)
plus, maybe brake clearance problems.
Better to buy wheels that were designed for the car, then try to make some work that were not.
bearclaw46
Race Red
Dec 31, 2016 02:48 PM
Pirate_5.0
Feb 16, 2016 08:12 PM
lakeguy77
Feb 1, 2016 04:39 PM
grandpa mustang
Jan 31, 2016 04:26 PM
