5.0 GT + Boss 302 Intake Manifold Idle Issue
Old Sep 9, 2011 | 01:23 PM
  #41
99mstng's Avatar
Originally Posted by blackgt87
A grand? I bought the Boss mani and all parts needed for 400 bucks brand new and installed it myself in about an hour and a half.
+ intake + tune/tuner puts you well over a grand total
Old Sep 9, 2011 | 01:35 PM
  #42
blackgt87's Avatar
Are we gonna add in the cost of gas to drive it and the oil because you put miles on it? Adding anything in for wearing the tires down? Or brakes to stop it, or the clutch disc?
The boss manifold is a "next step" kinda mod, if you're not the kinda mustang owner who already has a tune, and CAI, then the high rpm nature of the boss manifold is almost certainly not for you.
Old Sep 9, 2011 | 07:59 PM
  #43
MyStang2010GB's Avatar
Originally Posted by SteedaGus
Its intoxicating to have a car pull hard up top like a Boss intake car does. Once you drive one you want to do it again..... Take it from someone who has
I totally agree !!
Old Sep 9, 2011 | 09:11 PM
  #44
99mstng's Avatar
Don't forget the cost of air for the tires no I'm in no way complaining about the costs. All I said was I'm sure if I drove one I'd be $1K poorer. If I want to go faster in the meantime I'll hop on the bike and rev it to 16K
Old Sep 12, 2011 | 08:11 AM
  #45
NickDC123's Avatar
Getting back to the original purpose of the thread ...
I took everything apart and re-assembled. Was able to replace the 2 sheared bolts and was very careful about the fitment issues with the B302 throttle angle vs. the Steeda CAI. Tried the carb cleaner spray and I really have no vacuum leaks. BUT, alas, still the issue with the fluctuating up/down idle (550 - 750) + the occasional stall out on idle.
With the manifold out I did notice some brown coloration on the intake ports (which I think is indicative of running with too much fuel). I tried the set up with both the 87 Performance and the 87 Street tunes from Bama ... no difference. One odd thing is that I have a hard time restarting after getting gas (odd), but, once I get it going, it's fine.
Bama continues to be super helpful and I am sending them another data log tonight. Any ideas, guys? (Oh, and I bought a set of fuel injector o-rings (18) but turns out I didn't need them b/c ever one of the single green o's were still on the injectors.).
Thoughts?
Old Sep 12, 2011 | 09:08 AM
  #46
ShaneM's Avatar
i'd replace the o-rings anyway maybe one is nicked or torn. as i said before, that is the exact issue that my buddy had and it was a vacuum leak. the brown you saw in the intake is likely oil blow-by, these cars are notorious for that and it doesnt take long to get noticeable oil in the intake. i didn't read all of this, but did you spray the TB cleaner around the outter edges of the intake? if you do and the idle clears up when you spray in one spot you know that is your issue area. it might be worth it to take the car to a shop with one of those smoke machine testers that can pinpoint leaks.
Old Sep 12, 2011 | 10:26 AM
  #47
RedCandy5.0's Avatar
Can it just be your tune? I have a few tunes and a couple have idle issues that can not be resolved but 2 of mine the car idles and runs better than stock.
Old Sep 18, 2011 | 07:40 AM
  #48
NickDC123's Avatar
Well it was the tune! I hooked the fuel vapor purge line back up with the sensor and got a new tune from Gus at Steeda and all is well !!! Can't thank Gus & Steeda enough for jumping in and volunteering to help me !!!!! I am happily motoring again
Old Sep 18, 2011 | 07:43 AM
  #49
Not all tunes are created equal.
Old Sep 20, 2011 | 08:57 AM
  #50
SteedaGus's Avatar
Thanks for letting us help and thanks for using our product!
Old Sep 20, 2011 | 09:18 AM
  #51
blackgt87's Avatar
I ran a tenth slower with a Boss intake and Steeda tune over stock intake and Bama tune.
Bama tune for the Boss intake was awful down low, tons of lost torque, I probably should have ran it too but I'm confident it would have been even worse.
DA when I ran with the stock intake was 2700, DA when I ran with the Boss intake last friday was 500, so the losses were actually worse.
More than likely going back to stock, unless I want to spend more money on a dyno tune...
Old Sep 20, 2011 | 09:36 AM
  #52
Talk to Shaun at AED before you go back to stock and see what he says. The guy is a tuning master and will give you the truth if you can get it all sorted out or not.
Old Sep 20, 2011 | 10:06 AM
  #53
blackgt87's Avatar
Thanks man I will give him a call.
Old Mar 27, 2013 | 03:13 PM
  #54
JMDoll's Avatar
Boss manifold
BamaTunes - using 87 Performance now. I had them before the Boss302 and in my '05 w/o any issue at all. I sent them a bunch of diagnostic info and they are being EXTREMELY helpful. Just wondering if anybody else had this issue too. I had some fitment issues with the intake and I am wondering if I am getting like a back flow issue? I do indeed notice the power difference, so, I did something right ... maybe ...
I'm having the exact same issues but don't know where I could have a vacuum leak? How far did you torque the bolts down? Did you snap any?
Old Jun 7, 2023 | 10:31 AM
  #55
manny.what's Avatar
Anyone having idle issues with after putting a Boss 302 intake manifold on a base 5.0 GT (see signature for configuration). I have a fluctuating rpm issue at idle that goes as low as 500 rpm and then spikes back over 1000 rpm. Sometimes the engine kills and I have a challenge getting it restarted (but one it does, then, no more issue for a while. Bama is helping me with diagnosing, but, wondering if any of y'all have had this issue.
Hey I have the same issue and VMP whom did my tune doesn’t think it’s them. What did you do to solve it op?
Old Jun 7, 2023 | 12:38 PM
  #56
05stangkc's Avatar
manny,what
Topic is From 2011, Op Last Activity Was in 2013! So No Direct Answer Likely! That Being Said Thanks For Stopping By and If Any of Our Current Members Have Some Direct Experience with This Issue Please Chime In!
We Also Invite You To Post Pics & Give Us Some Info on Your Ride In Introductions!
KC
Old Jun 7, 2023 | 07:17 PM
  #57
m05fastbackGT's Avatar
I'll second that!
Old Nov 28, 2023 | 03:52 PM
  #58
Trip's Avatar
Does your car have cats still? The only exhaust mod I have done is GT500 axlebacks, I think my stock exhaust is choking it.
To me I can for sure feel the loss of torque from 3-5k, but above that it just feel like it revs longer, not really pulls harder.
I’ve definitely noticed a increase in probably 30 or so hp power and maybe 15 fp/t, but i was pro-tuned prior to putting it on. Though i have a gain my idle seems off and my car is running hot after a drive with my fan kicking on I believe. Possibly just low on coolant because i had a issue i thought i fixed but wonder if the intake could be causing it now.
Old Nov 28, 2023 | 04:26 PM
  #59
05stangkc's Avatar
Welcome!
Look Into Bleeding Cooling System!
https://themustangsource.com/forums/...g-help-547838/
KC
Steve@CJPP
Sep 10, 2013 01:14 PM
elijah.m.baldein
Jan 23, 2013 10:25 AM
