5.0 Brenspeed Tune Problem?
Old Aug 6, 2010 | 12:54 PM
JobeNole44's Avatar
Just installed my 93 Brenspeed tune yesterday. Today, while going from 1->2 at hard acceleration, my car jerks and goes into limp home mode. Also throws a code, P061B. This code means the ECU is detecting that my engine is putting out too much torque for a stock engine. Anyone else had this problem with any tune? I emailed Doug to see what his recommendations are. Anyone have any advice for me? I reloaded the SCT tune for now. From what I experienced for a short time, Doug's tune was great. Don't want to leave it on if it causes limp home mode though...
Old Aug 6, 2010 | 01:02 PM
stangfoeva's Avatar
MOTM Committee Member
thanks for sharing! Sorry I can't be of help, but this just makes it easier for me to wait for a tune from FRPP
Old Aug 6, 2010 | 01:28 PM
RedCandy5.0's Avatar
Who is Doug? Did you get your tune from Brenspeed (Brent) or American Muscle / Bama (dogue)?
Old Aug 6, 2010 | 01:30 PM
JobeNole44's Avatar
Maybe Brent made it but Doug@Brenspeed emailed it to me. IDK, kinda new to this. Assumed, maybe mistakenly, that the guy who emailed it to me was the tuner.
Old Aug 6, 2010 | 02:55 PM
Gene K's Avatar
Hmmmmm..... Im suprised Brice (Low 11 Whipple/FRPP Blown 2006) didnt talk you into gettig a tune from Justin at VMP Tuning .
Brenspeed should be able to get you straightened out. If all else fails Justin is within reasonable distance.
Old Aug 6, 2010 | 03:02 PM
montreal ponies's Avatar
What a bummer, i have no answer for 'ya since i'm running the '93 Steeda tune with no problems so far. Let us know what's up with that ! Good luck, i'm sure they will work it out for you.
Old Aug 6, 2010 | 03:41 PM
2010MustangGT's Avatar
That sucks, the guys over there are pretty reputable, I'm sure they'll make it right and get your tune in line.
Old Aug 6, 2010 | 04:04 PM
Ducky's Avatar
I was having the exact same issue with my V6, oddly enough it only happened if I used cruise control on a stock motor. If you turn the car off and back on, it will turn off limp mode. Doug should be able to just turn that code off, its not hurting anything.
Old Aug 6, 2010 | 05:17 PM
TTS197's Avatar
Sounds like a gear calibration problem. Did you specify that you have 3.73 when you ordered your tune?
Old Aug 6, 2010 | 05:21 PM
Ducky's Avatar
Its not.
Old Aug 6, 2010 | 05:26 PM
TTS197's Avatar
Originally Posted by Ducky
Its not.
explain.
Old Aug 6, 2010 | 05:36 PM
Ducky's Avatar
explain.
I already did. Its a not uncommon issue, and one that turners can turn off. I went 3.5 years with a tune and 3.73's on my V6 and tons of full throttle pulls. It only became an issue within the last few months, and only when using cruise control on a cold motor. I dont know why it suddenly popped up, but it did. I did some research and decided it wasnt anything to worry about, so I didnt bother paying for new tunes to get the issue resolved, I just traded the car in. I'm not sure how the motor senses torque, but the fact I went so long without issue leads me to believe it has nothing to do with gears. Oh, and your rear end gear is a end user adjustable parameter, he didnt have to specify.
Old Aug 11, 2010 | 06:10 AM
JobeNole44's Avatar
Thumbs up *Update*
So I contacted Brenspeed last Friday with my problem. Monday they tell me they will look into it. Yesterday I get an updated tune. They said they adjusted my torque variable as my computer must be sensitive. So I load it up and take the stang out. WOT in 1st, hit 2nd hard... and what is the opposite of limp home mode? It pulls soooooo hard in second and now pulls in 3rd as hard as 2nd pulled stock. Could not be happier. Thanks Brenspeed for the quick resolution and great tune. BTW, anyone have any suggestions to keep the wheels on the ground when I floor 2nd? Tire hop like mad. Great power, now need traction...
Old Aug 11, 2010 | 06:13 AM
I think that is the biggest problem. Everyone wants more power and bragging rights but what good it it if you can not get it to the ground ala GT500.
Old Aug 11, 2010 | 08:58 AM
desertMustang's Avatar
Then, once you get the power to the ground you have to start worrying about burning clutches. After that's solved you start thrashing u-joints and driveshafts. Once that's squared away, rear-ends start gnashing teeth. Stock form is more than enough for me.
Old Aug 11, 2010 | 09:01 AM
any one know if this unit fits that of the 2011?
http://www.steeda.com/products/stop_the_hop_s197.php
Old Aug 11, 2010 | 09:08 AM
I just think everyone is just jumping to quick on these tunes as they have not been tested in the real world for a decent amount of time. Why would you want a tune on an engine that has not even been tested in stock form for any amount of time unless this is a track car. I would wait at least until next spring to get some real info as some cars are having trouble with these tunes already.
But you are right about the trickle down effect.
Mpaps
Oct 11, 2017 08:06 PM
Cdvision
Sep 5, 2015 05:22 PM
Kestral
Sep 2, 2015 06:52 PM
