3M adhesive prep?
Old Jul 17, 2012 | 04:23 PM
wannabe's Avatar
3M adhesive prep?
Putting on some Roush rocker/splitter trim tomorrow. Directions say use 3M 'adhesive prep' to clean the surface prior to sticking. In the past, I would ignore this and just use acetone, which I have handy... but the older I get, the more inclined I am to actually follow directions. But I have to ask... is the 3M really necessary??
Old Jul 17, 2012 | 04:38 PM
Mikey's Avatar
I installed the Roush side splitters a couple months ago... On a clean car, just rub the bottom side of the rocker panels down with rubbing alcohol or acetone and let it dry. No need for the 3M adhesive prep.
Old Jul 17, 2012 | 04:40 PM
Planeswalker's Avatar
The prep should have an adhesion promoter in it, which helps the tape stick to unpainted plastic. Do not use it on painted pieces.
Old Jul 18, 2012 | 05:46 AM
Bucko's Avatar
I'll guess if you follow directions to the "T" and something goes wrong, you have a case.....if not, then you can't complain when it goes wrong.
Old Jul 18, 2012 | 01:40 PM
dusman59's Avatar
I used the prep when I put the splitters on. I had to go twice to a automotive paint supply to get some. First time I left the stuff in the car and the package blew up from the heat. Lucky it was in a bag so no damage happened but the fumes were bad. I did not know storage on the package says 60f to 80f degrees. Guess the AZ temp was quite a bit over. Lol
Old Jul 18, 2012 | 02:50 PM
2012GTCS's Avatar
No prep and they stuck fine. The 13 push pins are enough to hold it anyway.
Old Jul 18, 2012 | 05:28 PM
CannonBaller's Avatar
I also picked up the splitters.
And I don't even have my car yet!!!
You guys have any installed pics.
Be nice to see what they look like on the car.
Old Jul 18, 2012 | 06:38 PM
Mikey's Avatar
Here's mine...
Old Jul 20, 2012 | 12:41 AM
Originally Posted by Mikey
Here's mine...
Looks good.
Definetly one of the many extras that Ford forgot...as usual.
Check out this vid of the new 13 RTR Edition.
It has a nice 3 piece addon for the rear bumper that would compliment these. Come to think of it, it has the Roush side splitters installed also.
Does anyone know if these rear splitters are already out on the market?
Old Jul 20, 2012 | 12:14 PM
CDC Jake's Avatar
The RTR Rear Valance isn't yet available as a separate piece but it will be available through us shortly along with most of the other components you see on the RTR. It's definitely a nice addition to the Side Rocker Extensions!
Old Jul 20, 2012 | 12:49 PM
dusman59's Avatar
I see you will have them for the 13's but are they going to be available for the 11's and 12's
Old Jul 20, 2012 | 12:51 PM
dusman59's Avatar
Im sorry I ment the lower diffuser that goes with the side splitters
wheelman's Avatar
Cant wait, lovin the RTR stuff
Old Jul 20, 2012 | 01:30 PM
Will you guys also carry that new MagnaFlow exaust?
I think its the best one I've heard so far.
As close as I've heard to the 5.0s of the 80s.
I was able to get my 1999 Stang sound like that with Flowmasters.
But ever since teh 2005s came out, all the mufflers on the market just sound too ratty almost tinny.
The RTR Magnaflow has that nice low mellow rumble.
Old Aug 9, 2012 | 11:26 AM
Hey CDC JAKE,
When do you think that 3-peice rear valance will be available for order?
I'm ready to pull the trigger asap.
thanks
Mar 30, 2021 09:29 AM
tukatz
Off-Topic Chatter
23
Oct 20, 2015 09:54 AM
GLOCKer
Sep 28, 2015 05:20 PM
Sep 8, 2015 10:45 AM
