2013 Track Pack suspension any changes?
Old Mar 28, 2012 | 11:04 PM
BOSS302R's Avatar
I have read some mixed info on the track pack, some say its has some upgrades suspension parts and some say its just a brembo, LSD and 3.73 gears?
i want to install the steeda springs
http://www.steeda.com/store/steeda-s...d-mustang.html drops 1" front 1 1/4" rear but not knowing if the track pack will come with stock shocks or upgrade shocks/struts ?
Old Mar 29, 2012 | 07:42 AM
TheLeech's Avatar
It has upgraded suspensions part because it includes the Brembo package. The parts that are specific to the Track Pack are the larger radiator, the oil cooler, the Torsen differential with 3.73 gears, and the upgraded brake pads.
The general consensus is that the car is underdamped from the factory, so adding shorter, stiffer springs will only exacerbate the problem. If you're going to put those springs on, you might also consider upgrading the shocks/struts.
Old Mar 29, 2012 | 04:31 PM
BOSS302R's Avatar
thank you, but whats the "upgrade suspension" part?
Old Mar 29, 2012 | 05:31 PM
Thomas S's Avatar
If I'm reading it right, he's saying the suspension is the same as the BBP.
Old Mar 29, 2012 | 06:41 PM
TheLeech's Avatar
Here you go: http://brembo50.com/Default.aspx?pageId=1130035
Old Mar 29, 2012 | 07:20 PM
BOSS302R's Avatar
Originally Posted by TheLeech
thank you for that link, so my guess with the higher spring rates it will not dip down as hard during braking and might handle a little better on corners?
here is the extra
Different Springs (131lbs Front / 167lbs Rear) (stock 123lbs / 156lbs)
Different Struts/ Shocks (tuned for spring rates)
GT-500 Rear Lower Control Arms ( Higher Durometer Rubber)
Unique Electronic Stability Control® (ESC) Tuning
Unique Sport Steering Control Setting (EPAS)
JonsMustang
Mar 5, 2016 05:44 PM
5.M0NSTER
26
Sep 28, 2015 07:11 PM
JTB
Motorsports
Sep 3, 2015 10:50 AM
cloud9
GT350
Aug 18, 2015 01:34 PM
