2013 people with Shaker Pro, please come in...
Old Oct 24, 2012 | 07:45 PM
TheDivaDanielle's Avatar
Is there any way to turn the sub on or off? I noticed that while I have lots of bass, none really comes through the back. Popped the trunk after work, and verified that the trunk sub is doing nothing and I've found zero indication of an internal radio menu to turn the sub on or off like the old shaker 1000s supposedly did.
Please help!
Old Oct 24, 2012 | 08:35 PM
To add to this... When you set your fader to the rear do you actually get bass?
On my car to get a balanced sound stage where the rear speakers can be heard equally with the front, I have the fader set three notches towards the rear. Is this the same for anyone else?
When I sit in the car, keep in mind there is an abundance of bass, from the doors though. No sound seems to come from the back.
Old Oct 25, 2012 | 05:38 AM
Snoopy49's Avatar
Did you check the fuse for the trunk sub-woofer?
Pages 219-221 in the 2013 Mustang Owners Manual
The power distribution box is located in the engine compartment. It has
high-current fuses that protect your vehicle’s main electrical systems
from overloads.
Rear amplifier (Shaker Pro radio)
Fuse/Relay Number - 20
Fuse Amp Rating - 30A*
* Cartridge Fuses
Check the electrical connections in the trunk. Maybe someone didn't hook it up or it came loose.
Old Oct 25, 2012 | 06:32 AM
Fuses look okay, as do whatever connectors I could see in the trunk. :-(
Old Oct 25, 2012 | 11:14 AM
I don't know about your situation, but your use and understanding of what a "soundstage" is, is incorrect. The term soundstage is referencing your ears' ability to discern where each instrument in your music is coming from, on your dash. Music comes from in front of you! Fading your speakers to the rear, is ruining your "soundstage." Not that the Mustang has any adjustments for time alignment stock, but that's neither here nor there. You'd need an external processor to correct for time alignment.
Old Oct 25, 2012 | 11:15 AM
Good luck with getting your subs to work. I'm sure you'd rather not make another trip to your dealer...
Old Oct 25, 2012 | 12:49 PM
autobred's Avatar
I agree with Patrick. Rear speakers are just used for rear fill, to raise the front soundstage. Its exactly that as if you are at a show. If the rear speakers start pulling you to the rear then you know its too much. A good place to start is to fade everything to the front then slowly start fading to the rear where you hear your soundstage start raising to the windshield. Subs are non directional so you shouldn't be able to tell where its coming from. Something is definitely wrong though if its not coming on. EQ the mids and trebles off to see if the sub is not playing...
Old Oct 25, 2012 | 08:45 PM
JoesCat's Avatar
Hmmm, I don't see that option on Shaker Pro with Nav. Just treble and bass. It's very limiting.
Old Oct 26, 2012 | 09:00 AM
tbone004's Avatar
Try this to verify the sub is not working.
Operate the audio system in radio tuner (AM/FM) mode.
Press and hold preset buttons 3 and 6 for 3 seconds until the speaker walk test begins.
The display indicates each speaker as it is tested.
Check the following fuse. Someone already mentioned fuse 20, fuse 33 is also for the DSP Amp.
Old Oct 29, 2012 | 11:32 AM
Thanks t-bone, the sub is indeed not working! The car is now in for service on this.
Old Oct 29, 2012 | 12:56 PM
autobred's Avatar
faulty amp, should be replaced with no issue
Old Oct 29, 2012 | 12:57 PM
Amp was replaced already! This concerns me.
Old Oct 30, 2012 | 08:23 PM
Subiaur's Avatar
I had the same question but nobody answer me.. My Post
Seems my 2013 will be on the dealer soon
Danielle.. please comment all updates from your repair..
Old Oct 31, 2012 | 10:31 PM
I have a blown sub. New one on order for next week.
Old Oct 31, 2012 | 10:35 PM
11SHELBYGT500's Avatar
Turn that (c)rap music down.
Old Oct 31, 2012 | 10:37 PM
Yiruma is Sooo far from rap.
Old Oct 31, 2012 | 10:39 PM
I don't know what that is? Sounds Japanese
Old Oct 31, 2012 | 10:42 PM
Basically piano based solo stuff. Modern feel, lots of good feely love makin' kinda stuff.
Rando
Aug 25, 2021 11:12 AM
Cobiecane
Oct 23, 2015 08:44 AM
09-gt/cs
Oct 15, 2015 10:03 AM
