2013 GT-what should I have looked at
My GT just ticked over 91K and I've got to keep it for the foreseeable future. (I get a wilting side-eye from SWMBO when I mention getting a new one.) As it approaches 100K what areas should I look at or "no kidding-you've got to swap that out." Just had an oil change/tire rotation last week and brake pad life/rotor condition are not an issue. I'm pretty easy on my machinery.
Check/replace serpentine belts. Coolant hoses may be due. Manual calls for spark plug replacement at 100,000 miles so it can't hurt to get that out of the way. Spark plugs are really easy on 197 series cars with the 5.0 Coyote engine if you want to DIY. Just make sure to protect the positive battery cable/terminal from an accidental contact when doing # 4. Check ball joints and tie rod ends for wear. Have the shocks and struts ever been replaced? If not they are probably due. Most modern cars seem capable of at least 200,000 miles before major repairs are needed. Based on my experience with SN95 and SN197 series Mustangs these are really pretty tough and reliable cars. Obviously the more options any car has the more things there are that can and probably will fail at some point.
Thanks, Kyle. Maybe I'll take it by my neighborhood mechanic and see what he says. I prefer to get on top of it before something fails comprehensively.
Just a quick update: I had the local fix-it shop look it over and past experience has showed me that I can trust their pricing and their work. At 105K miles I had them replace both front hubs (pulsating sound developed in the front end especially in turns-bearings about to fail), went through and did an entire cooling system service (water pump, thermostat, hoses and belts), transmission and differential service, shocks and struts replaced all around, rear wheel seals, all spark plugs replaced, drain-flush-replace brake fluid, front brakes done. (The last was the biggest issue-part supplier sent 4 brakes rotors-3 were one size and 1 of another-all of them the wrong size. Stretched the process out another day that we weren't expecting.) Luckily in California auto repair is considered essential activity otherwise I was fearing it would have been left in partly assembled condition for weeks. The entire thing wasn't cheap but now its good for at least another 100k. Cheaper than a replacement. I just haven't been able to let it stretch its legs.....
A little late now but I keep up on maintenance so I can only hope for the best. Finally took it out for a freeway drive and it was noticeably smoother. Gee, thanks. Now I'll have another "mind worm" burrowing in the back of my mind.
check out this thread if you have some time on your hands: https://themustangsource.com/forums/...a-fool-547304/
Left Lane Muscle
May 21, 2017 04:03 PM
