2011 Trans V6!
Old Oct 15, 2013 | 05:46 AM
Icemann07's Avatar
2011 Trans V6!
Just Past the 60000 miles at 60157 om my 2011 V6. Something real strange happened the yellow wrench light came on and it acted like it wasn't in gear! Managed to pull over and turned it off and started it back up and it went away. I went straight to the dealer and they said they didn't see the problem but the guy pulled me to the side and said it will happened again so bring it back he has seen this before. SMH! Don't know what to think about this one......
Old Oct 15, 2013 | 06:42 AM
Ajcruz1's Avatar
Auto or manual?
Old Oct 15, 2013 | 09:19 AM
Ltngdrvr's Avatar
Originally Posted by Ajcruz1
Auto or manual?
Yeah, you guys need to make sure to post all your car info if you want good feedback on your issue.
Old Oct 15, 2013 | 10:30 AM
FordService's Avatar
Hello Icemann07,
Definitely stay in touch with your service manager regarding your this concern. They’ll be able to let you know if work or replacement is needed and whether there is coverage available (warranty, recall, etc.). Please keep me updated.
Deysha
Old Oct 15, 2013 | 11:47 AM
Womprat's Avatar
I hit a huge puddle in my 2005 v6 and the force of the water pushed the electrical connectors gasket into the connector, exposing the leads, and it went into Limp-Mode. I pulled all the trans connectors apart and cleaned them with CRC electrical cleaner, added some dielectric grease and wrapped them, never had the issue again. But what a pain, thankfully my buddys shop had a trans diagnostic computer to reset the codes.
Old Oct 15, 2013 | 01:15 PM
Icemann07's Avatar
2011 V6, Automatic, miles 60147 out of factory warranty but I still have extended warranty. Sorry for not enough info!
Old Oct 16, 2013 | 04:05 AM
Icemann07's Avatar
Originally Posted by FordService
Hello Icemann07,
Deysha
Will Do!
Old Oct 16, 2013 | 05:35 AM
Will Do!
Great!
Deysha
Old Oct 20, 2013 | 01:46 PM
wanted33's Avatar
Iceman, it could be something as simple as a throttle body sensor. Our 2010 did the same thing, wrench came on, it then went into limp mode. I turned it off and back on, and it cleared up. It did rear it's ugly head again real soon. However, mine threw a code for the tech to read. Good luck, I hope it's a simple fix or doesn't happen again.
Infamous_blackbeard
Oct 8, 2015 10:45 PM
MustangConvert11
Sep 30, 2015 08:01 PM
Road_Runner
Sep 10, 2015 11:28 AM
