2011 Steeda Suspension - Upper 3rd Link Info
Before I get started as a reminder Mustangsource members get preferred pricing on any Steeda manufactured part and can PM me at anytime for pricing.
As many of you may or may not be aware Ford revised the rear upper 3rd link in the 2011 Mustang. It is slightly longer than the previous models and also uses a larger front bolt for chassis attachment.
Our standard upper 3rd links will not work for the new model, but our 555-4106 and 555-4109 adjustable upper 3rd links with the stronger replacement chassis mount, will.
Some of you may also be familiar with our 555-4110 stepped spacers which are included with our standard upper 3rd links but can also be ordered separately for those that have other brands of 3rd links. This fixes a fundamental issue in the Ford chassis mount for the 3rd link on 2005-2010 models.
Unfortunately although Ford changed the front bolt at the chassis mount in 2011, the fundamental issue we use the stepped spacers for still exists.
In 2005-09 vehicles Ford was using a 14mm front bolt in a 16mm hole. This gave room for the bolt to move. This allowed the upper 3rd link to move back and forth under the stress of acceleration and bumps. This would manifest itself as rear suspension noise particularly over bumps with aftermarket upper 3rd links. Our stepped spacers reduced the hole down to 14mm eliminating this issue.
Now with the 2011, you have a longer rear upper 3rd link with a larger 18mm chassis bolt, but with a nearly 20mm hole. We believe Ford did this for ease of assembly on the assembly line, but for increased performance applications unfortunately this does not work well.
For those who are looking for a better upper 3rd link for their 2011 Mustang part numbers 555-4106 and 555-4109 include new chassis mounts. Ours were originally designed to be longer than the 05-09 links, which Ford obviously saw as a benefit and incorporated into the 2011 Mustang, but our links are adjustable for pinion angle and offer the choice of urethane bushings or spherical bearings for reduced deflection and improved performance/durability.
Our heavy duty chassis mounts are 1/4" thick steel, twice as thick as the original chassis mount use a 14mm bolt in a 14mm hole which solves the issue of the bolt walking in the chassis mount hole as well.
Part# 555-4106 is our full competition version with a spherical bearing at the chassis end. This link will produce NVH in a street application and is recommended for competition use only. Retail 279.95
Part# 555-4109 is our dual purpose street/track version with urethane bushing at the chassis end for near O.E. levels of NVH and smoothness. Retail 289.95
SteedaGus: Wondering if the 14MM bolt in a 16MM hole problem is what is going on in our 2007 GT/CS? When ever we hit a road bump or ridge in the highway the whole rear end becomes some what unsettled and thumps rather loudly! this seems to be getting a little worse all of the time. Feels like a twisting rotational bobble if that makes any sense at all? What is your opinion on this? CalStang
9/1/15 01:19 PM
ustabawannab
8/5/15 08:32 PM
