2011 Active Security
i have only had this working once
how exactly do you arm it, i know i double locked it on my first day and went to grab something thru the window and it went off, i then double locked it again and pulled the door handle and it went off...but now i cant get it to go off at all
Just lock it with the remote and wait a few seconds. Put an arm in the car with the window down and that motion should set it off. It has sensors mounted in the roof panel not far from the dome lights.
If you cannot set it off check the fuses and schedule a service appointment if it is anything more than a defective fuse. STAY WITH YOUR CAR AT THE DEALER.
Arming the system
When armed, the active anti-theft system is designed to notify you of an
unauthorized entry. When unauthorized entry or towing occurs, the
system will flash the turn signal lamps and interior lamps and will sound
the horn.
The system is ready to arm whenever the key is out of the ignition. Any
of the following actions will arm the alarm system:
• Press the control on the remote entry transmitter portion of your
integrated keyhead transmitter.
• Lock all doors using the interior power lock switch while the driver or
passenger door is open and then becomes closed.
• Lock the driver door with the key in the key lock cylinder (this will
not however arm the interior motion or vehicle incline sensing
systems).
There is a 20 second countdown when any of the above actions occur
before the vehicle becomes armed.
Each door, the hood or the trunk is armed individually, and if any are
open, they must be closed for the system to enter the 20 second
countdown.
The turn signal lamps will flash once when all doors, the hood and the
trunk are closed indicating the vehicle is locked and entering the
20 second countdown. If any closure is not properly closed the turn
signal lamps will not flash and that closure will not be armed.
the horn.
systems).
countdown.
