2011-2012 Skip-shift goes away after axle-back?
Old Nov 13, 2014 | 08:03 PM
HizliBullet's Avatar
This may and will sound unheard of or plain dumb but 2 years ago I read somewhere that if stock exhaust is removed, the skip shift feature wouldn't work. i don't use this feature but i don't want to lose it either. i'll be getting the ford racing exhaust axle back m-5230-mgtla (no drone version) in summer, but my ford technician couldn't answer me
Old Nov 13, 2014 | 08:07 PM
Joeywhat's Avatar
How exactly would that work...?
The exhaust isn't tied into anything even remotely related to skip shift (especially just the axle backs). So in short, no...it won't change that.
Old Nov 14, 2014 | 07:53 AM
dmhines's Avatar
Only way to disable Skip-shift is with a Tune ... you can disconnect the Solenoid but the Dash message will still show. Why in the world would you not want to lose this feature? Even Ford was Smart enough to not include it in 2013.
Old Nov 14, 2014 | 08:03 AM
zeroaviation's Avatar
Dan is indeed correct.
However, I can help you cut off skip shift for much cheaper using another device. PM me if interested.
-Matt
Old Nov 14, 2014 | 09:03 AM
5.M0NSTER's Avatar
-Matt
The only one plausible explanation i can think of is that once you put on aftermarket exhaust, you tend to shift over 3000rpm to hear it roar, which effectively turns of skipshift.
Old Nov 14, 2014 | 11:00 AM
everyone has valid points guys, i dont know how to make it come on on my stock axle back, it happens on its own, does it sense the airflow or something?
Old Nov 14, 2014 | 11:13 AM
Brandon302's Avatar
It's RPM and probably load based, if you are slowly accelerating it will happen. I can't see why you would want it in the first place, probably the most annoying thing about the 11 and 12 cars.
Old Nov 14, 2014 | 11:16 AM
dmichaels's Avatar
glad I don't have skip shift
Old Nov 15, 2014 | 08:45 AM
MJJ's Avatar
MJJ
This is the first post I have ever seen where someone wants to keep skip-shift!
Thankfully the Shelby does not have skip shift. Personally I think this is a safety hazzard more than a gas saver.
Old Nov 15, 2014 | 11:19 AM
Right! Just do it on your own if you choose. Don't need a "nanny" device forcing you to.
Old Nov 15, 2014 | 06:22 PM
Ford tech doesn't see a point in it either since shifting 1 to 4 can damage the transmission
Old Nov 15, 2014 | 06:30 PM
dmhines's Avatar
How you figure that?
Old Nov 15, 2014 | 07:16 PM
redneb's Avatar
Absolutely hate this feature on my 12 GT. I have heard removing the wire to the solenoid on the tranny will disable it. Does anyone know if there is anything I should be concerned about if I pull this wire? I don't want an idiot light coming on due to this.
Old Nov 15, 2014 | 07:20 PM
dmhines's Avatar
I unplugged my solenoid as soon as I got home from the dealer after buying it. Had 20 miles on the car. it causes no error lights or DTC's unplugging it - message will still display in cluster. I have since flashed my ECM to a 2013 calibration so no longer have skip shift enabled.
Old Nov 16, 2014 | 03:57 PM
redneb's Avatar
Thanks Dan. I will be disconnecting the solenoid wire.
Old Nov 19, 2014 | 11:59 AM
wanted33's Avatar
Corvettes have it, and it was the most aggravating thing I've ever had on a manual car. But I'm sure the Mustangs are the same, it was rpm regulated. So, axle-backs won't affect the ship shift unless it's like another post says. You run the engine faster just to hear that beautiful music the GT500's make.
Old Nov 19, 2014 | 03:51 PM
Even though my concern has been addressed I'll share this info for those that want more info on skip shift disabling
Old Nov 28, 2014 | 12:03 PM
redneb's Avatar
Even though my concern has been addressed I'll share this info for those that want more info on skip shift disabling Video Link: http://www.youtube.com/watch?v=Ejmguo8WrtY
Thank you for the link.
Sep 24, 2015 08:15 PM
Sep 10, 2015 12:44 PM
drmag
Sep 1, 2015 03:47 PM
Kaleb LaCoste
Aug 6, 2015 06:57 AM
