Notices
Sponsored By:
Sponsored By:
2010 track pack vs 11-14 brembo pack and track
Old 5/3/14, 05:52 AM
pminri's Avatar
I think you will find the baffle inside the oil pad is different.
Old 5/3/14, 06:23 AM
Gogoggansgo's Avatar
Originally Posted by lakeguy77
Boss engines aren't dry sump, they just have additional baffling to reduce oil sloshing around under high g forces. The track pack gets the Boss' oil cooler, but this is the first place I've seen the pan listed as an included part and will research that tonight, as I suspect that is incorrect as well.
it's there trust me
Old 5/3/14, 06:26 AM
Capacity means nothing. I have the spec sheet in front of me, both standard and track pack engine oil capacity is 8qts.
First of all its 8.5 quarts but ford has all 5.0 s including boss 302s have 8 quarts thrown in u don't know why both 2012 boss 302s and early track packs call for 8.5 quarts it was revised later
Old 5/3/14, 06:40 AM
lakeguy77's Avatar
Well I can assure you that the Boss brake lines are most definitely NOT included in the Track Pack. Different part numbers in the catalog, and dirtyhippracing.com has one of the best write-ups and break-downs of Track Pack part numbers I've read yet. And one of the upgrades they did, was adding the Boss brake lines.
Old 5/3/14, 06:57 AM
[QUOTE=lakeguy77;6798494]Well I can assure you that the Boss brake lines are most definitely NOT included in the Track Pack. Different part numbers in the catalog, and dirtyhippracing.com has one of the best write-ups and break-downs of Track Pack part numbers I've read yet. And one of the upgrades they did, was adding the Boss brake lines.
There on these cars the list I posted is from ford
Old 6/21/14, 05:35 PM
updated
Old 6/21/14, 06:50 PM
Uncle Jonfrey's Avatar
Any additional oil capacity on gt tp cars is for oil cooler
Old 6/22/14, 10:15 PM
Yes sir you are correct but the 15s are using 5w20 while the track packs use 5w50. Hmmmmmmmmm
robjh22
'10-14 Exterior Modifications
10/9/15 02:49 PM
dblhelx
10/6/15 08:08 PM
M3hunter
9/10/15 09:26 AM
9/8/15 10:45 AM
mustangsally_
05-09 Interior and Audio Mods
9/6/15 10:28 PM
Quick Reply: 2010 track pack vs 11-14 brembo pack and track
