2010 Lowering Springs
Old Sep 10, 2009 | 06:35 AM
karrnutt's Avatar
Has anyone installed Roush Mustang extreme lowering springs on their 2010 ? I would be interested in hearing opinions about them or other springs that drop the front 1"and the rear 1.25".
I do feel the 10 needs to be lowered but I would like to do it comfortably without the need for an additional shock package. This is a daily driver and will never see any track time.
Old Sep 10, 2009 | 06:43 AM
Branman's Avatar
Im on the hunt for some nice springs as well. I dont want a reversed rake which some springs will give you. I agree the 2010 does need to drop a tad but not much though.
Old Sep 10, 2009 | 12:26 PM
Rampant's Avatar
The lower you go, typically the higher the spring rate will go which will increase the need for shocks/struts.
The regular Roush springs are designed to work with the stock dampers and a bit less of a drop (and probably what Branman is looking for), but the extremes are meant to go lower.
To really get a "factory soft" but lowered ride, I really would look at a street coilover. It is harder to make it low and soft since suspension travel is reduced (necessitating a higher spring rate to keep off the bump-stops). Many coilovers will have shorter shock/strut bodies or other features to keep the travel pretty much the same, which usually means they can run softer springs, which usually equates to softer ride. Plus, the better (and matched) dampers control the springs a bit better, making for a bit smoother ride.
Now, if you don't run it very hard, and don't have sticky tires, you could probably get away with the Roush extreme springs and keep the stock dampers for awhile (maybe a long while) and then upgrade the shocks later if you wish (or need to). However, I personally have not done that.
Old Sep 10, 2009 | 05:06 PM
bpmurr's Avatar
I put FRPP Springs on my GT500 1.25 inch drop front and back.
Old Sep 10, 2009 | 06:14 PM
crescent_wrench's Avatar
Did you have to make any other mods to the suspension? How's the ride? Looks great BTW!
Old Sep 10, 2009 | 07:59 PM
kona stang10's Avatar
Here are some pics of my Eibach sportline lowered suspension, currently the lowest drop of all kits....
click onthe images to enlarge them:
Old Sep 10, 2009 | 08:57 PM
MyStang2010GB's Avatar
I went with the FRPP M-5300-K springs...
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old Sep 10, 2009 | 10:45 PM
bpmurr's Avatar
Just an adjustable panhard rod and alignment. It rides no different then stock. Love it!
Old Sep 11, 2009 | 06:18 AM
Branman's Avatar
looks bad ***! what is the part number of your springs?
Old Sep 11, 2009 | 01:06 PM
polodinks's Avatar
i got sportlines on my 08 and i love them..... you car is sittin so low and nice...... hot car man, hot car
Old Sep 11, 2009 | 01:16 PM
future9er24's Avatar
GREAT stance
Old Sep 14, 2009 | 07:53 AM
karrnutt's Avatar
Installed just the rear roush muustang extreme lowering springs,waiting for assistance fron a friend to do the fronts. Levelled the car and firmed up the ride ,still very acceptable ride.The first pic is after and the other is before.
Attached Thumbnails 2010 Lowering Springs-100_4019_edited.jpg   2010 Lowering Springs-000_0011_edited.jpg
Old Sep 14, 2009 | 08:25 AM
Looks great! Any alignment issues to worry about after you do the fronts?
Old Sep 14, 2009 | 02:49 PM
bpmurr's Avatar
M-5300-L
http://www.fordracingparts.com/parts...tKeyField=9882
They say they are for 07-09 but they work for the 2010 GT500. I don't think they'll work on a GT though.
Old Sep 14, 2009 | 08:53 PM
The GT uses the M-5300-K which is the 1.5" lowering springs. In addition they have a new spring kit that lowers 1.0"....
Old Sep 14, 2009 | 09:32 PM
oh i forgot to mention that i also have the Eibach front and rear sway bars with the kit and i added QA1 12 way adjustable shocks to the rear, not only is the car fast it really feels fast with this setup.
Old Sep 20, 2009 | 10:57 AM
karrnutt's Avatar
Post
Got the whole Roush Mustang extreme lowering kit installed now. It is made to work with the stock dampers and really does a great job. The stance is better, the ride is firmer but still very comfortable, and the car handles much better . There were no alignment issues front or rear. I'd rate them as 3 stars out of 3 !
Old Sep 20, 2009 | 12:26 PM
Branman's Avatar
looks awesome
Old Sep 22, 2009 | 03:44 PM
karrnutt's Avatar
The more I drive it the more I like it ! When I did Steeda Ultra Lites on my 05 the look was great but the ride was harsh.I don't think I have lost any of Ford's improvements with the Roush springs.
Old Sep 22, 2009 | 08:50 PM
Branman's Avatar
anymore pics?
