2010-12 GT500 steering wheel retrofit to 2014?
It's curious, if one were to get a GT500 steering wheel from a 2012, can the switches swap from your 2014 wheel to make it work?
LEXiiON
I much prefer the look of the GT500 wheel to the Boss and the price is definitely better as well.
This is the wheel you used, right? http://www.levittownfordsupercenter....00-p-1231.html
Thanks so much for any/all info!
-Evan
If you don't mind, could you give a little more info on what you had to do to make the wheel work? My car has the track apps, up-down-left-right buttons on the left side, is this what you used as well? Any tips?
-Evan
-Evan
LEXiiON
Glad we got this thread going. I'm in the process of getting another GT 500 Wheel. I'm just waiting to order it until I get back from vacation! Woo hoo!
There's plenty of threads where folks have swapped the switches out for the 13-14. After that it's plug and play. You can even change spokes.
I started a thread about this and posted a link to the best price on the net. I would order ASAP as the prices climbed since then.
The premium wheel is great but the GT 500 wheel is better. I had it on my prior sixer and on my GT soon.
Also Patrick when the time comes. Be VERY careful with the switches. Yes they simply slide out but are quite stubborn. You won't break them but could easily scratch them. In my book, it's the same thing.
Gotcha thanks, I was going to blue painters tape them prior to the swap. Good idea?
That's the only thing I miss on my old car. The premium wheel is slippery and skinny. The Alcantra grips are thicker on the GT 500 wheel.
Great idea. Even use some style of plastic tool to wedge them out. Even though a flat head screwdriver works dangerously better. That's the only thing I miss on my old car. The premium wheel is slippery and skinny. The Alcantra grips are thicker on the GT 500 wheel.
No puller necessary. Two tiny bolts on the side of the wheel. (Under the rubber plugs) and one large bolt under the air bag, that's it.
You'll spend more time disconnecting the battery and praying the airbag doesn't go off then actual wrenching. Lol
Lol oh jeez...yeah with my luck....
OK, so I installed the wheel tonight, swapped both sets of buttons and the harness with no problem.. BUT.. Now my cruise control isn't working. Any ideas? Does the car have to relearn something before it starts working again?
I pulled everything apart and made sure all of the plugs were secured and everything looked good.
Scratching my head...
On the 2010-12 the cruise cable is in slot 2 of the switch connector and on the 13+ it is in slot 1.
LEXiiON
Yes, I swapped the harness and both left and right side buttons. Everything that was in the original wheel is now in the new wheel.
