0-60 - what does track apps say?are they?
Old Jun 6, 2015 | 08:18 PM
jim010's Avatar
I am trying to determine what is normal for a 5.0 automatic and I am asking those of you with Track Apps - what are you recording in Track Apps for a 0-60 time?
My car is a 2012 5.0 automatic. Running on 91 octane, I am able to achieve 0-60 of 5.5 -6.0 sec. Once I did 5.2 This seems slow to me. What are all of you getting with your automatics? Please share.
Cheers
Old Jun 7, 2015 | 12:12 AM
stewarts359's Avatar
Well I've done a 5.2 in my stock manual
Old Jun 7, 2015 | 03:40 AM
2011 Kona Blue's Avatar
Cheers
You're track apps must be way off. My slow little 3.7 automatic runs 0-60 mph around 4.7 seconds
Old Jun 7, 2015 | 07:29 AM
Turbo302's Avatar
Just last weekend I got my all time best of 4.5 sec 0-60. 100%stock fully loaded late 2014 5.0 6A car.
Was in "s" mode trac control on and I just stomped on it from dead stop with perfect traction.
I don't buy any stock 3.7 being anywhere near sub 5 sec. I've driven plenty and there a pooch. Maybe get lucky with sticky tires and an aggressive launch stick car, but no way stock showroom condition.
Old Jun 7, 2015 | 12:58 PM
jim010's Avatar
OK, I am slower than I should be, then. Do you consistently get 4.5? With a tune, I've gotten 5.1 - 6.0. I don't think I'm getting all my ponies under the hood.
Old Jun 7, 2015 | 01:13 PM
Joeywhat's Avatar
If you're getting that wide a range, I'm betting it's a driver issue more then anything.
If you have traction control on then it will be a serious challenge to get anywhere close to the rated time. You'll also have to be good on the throttle to keep from just spinning the tires for a while.
Old Jun 7, 2015 | 04:43 PM
You absolutely correct that a stock 3.7 is not getting sub 5 second 0-60 mph. My N/A 3.7 is far from stock and has no issue using its 300 rwhp, 3:73 gears achieving under 5 second 0-60 mph runs. Because the lack of torque in my 3.7 I don't have traction issues when the temps and roads are warmer so it hooks fine with factory tires.
Old Jun 7, 2015 | 04:48 PM
Cdvision's Avatar
That's all I have to say.
Old Jun 7, 2015 | 04:52 PM
Cdvision's Avatar
I pulled a best of 4.4 with my wife's 5.0 stock. Had to roll on the throttle and it was still hazing the rear tires a little. I'm at sea level so that makes for quicker times than higher altitudes.
Turbo302's Avatar
This was my all time best. I don't drive the car often and it currently has 2300 miles on it and I ran that 4.5 just recently. I figure it's "loosening up" and getting stronger. Mine is a "late 14" which has the 2015 head castings. When it had around 1000 mi on it I ran at strip and did a 12.9@109 and would consistently get between 4.6-4.9 at that point.
Old Jun 7, 2015 | 05:10 PM
Joeywhat's Avatar
Then why even comment? What is the point of telling us that your not-stock 3.7 can run a sub 5 second 0-60? How is that in any way useful for the OP?
Old Jun 7, 2015 | 09:26 PM
jim010's Avatar
The range was under different conditions, but being an auto, I can't imagine much input required on my end. I use the automatic start for timing.
I'll see what I get with trac off.
Old Jun 7, 2015 | 09:55 PM
Joeywhat's Avatar
With as much power as a GT has, yes it requires a bit of work on your end. Can't just mash the go pedal, with traction control on it will certainly reduce torque to the rear wheels to keep them from spinning. With it off it will certainly just roast the tires.
Need to be on the throttle just enough to get maximum acceleration without spinning the tires.
Old Jun 7, 2015 | 09:58 PM
jim010's Avatar
OK, I'll give it a go and report back. Car goes in for some waranty stuff and the airbag recall tomorrow, so I'll try again tonight or when I get it back.
Old Jun 7, 2015 | 10:34 PM
jim010's Avatar
Just came back and tried without trac. Although, I can't spin my tires with track off either - or even in sport track mode. Time was 5.6, but I didn't launch perfect. I need to do this on a quiter stretch of road.
Old Jun 7, 2015 | 10:56 PM
Joeywhat's Avatar
Turn advancetrac off entirely (long press the button). Sport mode allows only a slight amount of wheel spin.
Old Jun 8, 2015 | 06:12 AM
It helps the OP because he has a 370 rwhp 5.0 and no way his track app is correct when my cylinder deficient 3.7 runs 0-60 mph in 4.7 seconds, his stock 5.0 should be faster than my modded 3.7. The point is, his track app is not correct and far from accurate. No way a factory 5.0 is running low to mid 5 second 0-60 mph runs. They are far faster than that. That's the point.
Old Jun 8, 2015 | 07:59 AM
JoeMidnight's Avatar
Hey OP, yeah, try and turn off the nannies and give it another whirl. Best I got on my V6 was 5.7
Others here on the forum have achieved mid 4's you Should be able to be in the mid to high 4's for sure!
practice makes perfect... I wouldn't waste too much time eating away at your tires trying to achieve it.
Old Jun 8, 2015 | 08:36 AM
Turbo302's Avatar
One thing to consider is the elevation of where your at. I noticed Alberta is around 3500ft. Where I am in the Twin Cities MN is about 800ft. So I have denser air thus more power down here.
I remember driving my 92 Notch 5.0 through the Rockys once and felt like I had 30% less power up in elevation.
Old Jun 8, 2015 | 09:38 AM
jim010's Avatar
Good point. When I was doing most of this testing this weekend, I was in the mountains.
