HOW TO INSTALL PONIES?
I assume this is not a difficult mod. Can someone tell us how to do this the right way?
THANKS!
EZ
Sorry... meant to put this under the PONIES Topic
Hopefully it will be moved to the right spot. Talking about the Running Pony Emblems replacing the GT emblems.
THANKS!
EZ
Make sure that your GT emblems are warm. If you are getting into cooler weather you might want to heat them alittle with a hair dryer. This will help loosen the tape and you can slide a credit card or a similiar object under the emblem until it is removed. Get some "goo be gone" or other tape cleaner and get all residue off then mount you new pony emblems. Piece of cake, check out my avatar.
9/10/15 12:44 PM
