Ford OEM Parts {Oem Ford Parts Information & Links} Get Ford Parts from Forum Member 05stangkc {Ebay Sales Link}
Factory Navigation Units!
Old 12/27/06 | 08:39 AM
  #61
redmsgt's Avatar
KC just to let you know my original system in my o6 gt was the shaker 500. Thanks.
Old 12/29/06 | 02:15 AM
  #62
Hollywood_North GT's Avatar
Closet American
Hey Kevin:
One question I'm curious about >> does it say "Made in Japan" or "Made in China" on these units? Despite the fact that they're manufactured for Ford by Pioneer, I'm gonna guess it's the latter.
Old 12/30/06 | 02:43 AM
  #63
Closet American
Originally Posted by BlueGT
Okay, so I was able to answer one of my questions. The Navigation System appears to be compatible with the Shaker 500 (but not 1000). Now if someone could only verify that it will work with the '07 Aux connector in the armrest...
Should be able to connect your iPod using the single prong Aux jack in the center armrest console, fed from you iPod headphone output jack.
Those new iPod adaptor kits for the glovebox won't work with this particular NAV unit, however, at least not according to the statement in the accessories catalogue for the Edge (which employs the same NAV unit).
Old 12/30/06 | 04:15 AM
  #64
Closet American
Factory Navigation System is now listed on the Ford of Canada website; you can build the car with the NAV option ($2300 CDN).
Still don't see it listed on the Ford.com website though.
Old 12/30/06 | 12:33 PM
  #65
Mike McRann's Avatar
Add me to the list of a potential buyer of the Factory Navigation Unit. I had a chance to check one out at the dealer this morning when I was having my car serviced, and after looking at the features and playing around with it I've decided to look into getting one for my car.
Some of the features that I like on the unit is satellite radio already installed in the sound system, 6 disk in dash CD player, and of course the navigation feature (I wasn't able to look at the navigation feature as you had to have the disc installed, but the demo screen/features looked great.
Old 12/30/06 | 03:43 PM
  #66
Closet American
I've seen it in operation - it's pretty good. It also tells you ACTUAL street names, too, during turn-by-turn directions. So, not just "turn left at next intersection," or "turn left in 200 meters," but "turn left in 200 meters...Birch St."
Old 12/30/06 | 06:12 PM
  #67
Martimus's Avatar
Anyone have an idea whether or not this unit would support the Ford Mobile-Ease Bluetooth kit? Since we know its plug compatible with the Skipper 500, it ought to plug right in but I wonder if the unit would recognize it?
Old 12/30/06 | 07:34 PM
  #68
Closet American
That's a great question.
I don't know. It's compatibility with Mobile-Ease is TBD, as is its full compatibility with iPods, vis-a-vis the Aux-in jack in the center armrest console.
Might I suggest that if it doesn't work, just get yourself one of those Bluetooth earpieces and dial your phone using pre-programmed numbers/voice commands (assuming your phone has that). Much simpler than trying to add a Ford accessory part that may require some dash disassembly later.
"Skipper 500" =
Old 1/2/07 | 07:21 PM
  #69
Closet American
OK, according to the '07 Mustang ordering guide, the NAV system is most definitely NOT available with the Shaker 1000.
Correct, but this Does Not Apply to My Retrofit Units
Old 1/3/07 | 03:56 PM
  #70
nonstopred's Avatar
so its 1999?
Old 1/4/07 | 03:29 PM
  #71
rocket88's Avatar
I don't think KC wants the price posted here!
Old 1/4/07 | 10:51 PM
  #72
Outlander's Avatar
I'm interested, if TPIR.
Old 1/5/07 | 03:11 PM
  #73
05stangkc's Avatar
The Analog Admin!
Originally Posted by redmsgt
K C I am trying to get my 07 nav radio to work in my o6 mustang any help from your nav contact would be appreciated. Perhaps they. could give you the codes for the ACM ( audio control module) so that I could download that to the radio to see if it will work correctly. The radio is originally from a 07 mountainnear.
Sent Email to Red ms Gt
No Solution Found At this Time!
Sorry!
KC
Old 1/5/07 | 04:33 PM
  #74
redmsgt's Avatar
Sorry!
KC
Thanks for the update KC I emailed you.
Old 1/20/07 | 07:21 AM
  #75
BlueGT's Avatar
Question
So has anyone installed one of these yet? How easy was it to install the antenna? What is the power output? Is it comparable to the Shaker 500? How about some pictures? I'm waiting to hear how it goes before jumping in.
Old 1/20/07 | 09:27 AM
  #76
redmsgt's Avatar
I have installed and had no major problems with installation. I used the sat antenna from the 500 because it is less expensive and installed in under the dash pad with 2 way stick foam tape. As far as output I believe it to be even stronger than the shaker 500.
Old 1/20/07 | 02:19 PM
  #77
BlueGT's Avatar
redmsgt,
Glad to hear your install went well. I saw you initially had some problems. How long did it take you? How would you compare the quality/use/features of your nav. unit with the Shaker 500? Any chance you could show us some pictures of it?
TIA
Old 1/20/07 | 05:11 PM
  #78
redmsgt's Avatar
Just to let you know i am still experiencing the speed error code which has me late in position by about 75 -100 feet. Ford is apparently working on a fix for this .It is happing on Ford 500 as well but not every unit which is puzzling them. Other than that minor annoyance it is an awesome unit with so many features and is very easy to operate.I dont have any pics however it is the same unit that is used in most new F0RD and LINCOLN cars. Looks great in the dash and is aperfect fit.
Old 1/25/07 | 07:19 AM
  #79
ba2's Avatar
ba2
Kevin,
Just found your site. Would you send be update on the nav system for my 07 GT. I have the Shaker 500 with Sirius. Would like cost and installation charge.
Thanks,
Old 1/25/07 | 04:03 PM
  #80
05stangkc's Avatar
The Analog Admin!
NOTICE!!!!!!!!! 12/26/06
Nav Units are Now Available and Priced in My Current Hotsheets!
These units are Plug and Play and Will Work With Premium , 500 And YES Shaker 1000 Units. To Order All I will Need Is Year and Radio Style. This Unit will Accept the Sirius Kit. You Can Have it All! These are Specially Programed and Not Just an 07 Replacement Nav Unit. If you Attempt to Merely Purchase an 07 Unit at your Local Dealer it may or may not work at all. FYI My Kits Come with Antenna and Nav Disc! These are not Programmed to Play DVD's Since they are Visible to Driver.
KC
Read Sig For Pricing Info!
REMEMBER!
Quick Reply: Factory Navigation Units!
