2010 guage cluster in 05 - 09?
I quite like the new guage faces and needles for the 2010. Kevin, do you know anything yet as to whether the 2010 guages would work in the previous cars? Hell, I'd just buy the needles.
The white guage definitely caught my eye.
Cheers
Cheers
Okay. Go Sit in your Mustang. Put one hand on the shifter. Now put the other hand, where it would be for Maximum control, on your Steering wheel, as if you were Standing on it, Pedal to the Metal, on the strip.
Now........Look where your arm is!! Bet you can't see your Tach.
Case closed!
Case closed!
Hmmm... I can see my tach. Sounds like you may need to adjust your seat and/or your steering wheel!
I can understand that. The upper left part of my tach can be cut off, and I do have to duck my head a bit to see it while flying up the on-ramp at 80mph.
The Analog Admin!
Received 3,157 Likes
I will need a Car on the Lot and the 2010 Shop Manual Before I would Guess on that One.
KC
Case closed!
Case closed!
79-04 had the tach on the left, never had a problem, NEVER heard one complaint about it.
i could see it being block if you have your hand on top of the wheel, with a sweet gangster lean to the right.
"maximum control"?? are you kidding? arm braced on the door panel, hand at 9 oclock, is best method to keep the car straight......unless your trying to "break the wheels loose on every shift" by jerking the wheel to the right or left on every shift. so your "boys" think your car is super bad, like fast n furious!
I lust for a M24
this is the most ridiculous thing i have ever heard! did you think this up with your friends while "hangin" at starbucks? with your ford racing jackets on?
Regardless of how you drive, many people who drive stick, including myself who has driven stick for years will have their left hand near the top of the steering wheel while their right hand is on the gear shifter. When driving like this, your left arm does in fact block the tach. Also note that Shelby, etc has placed the tach on the right even on the 09 cars to avoid this very problem. Your post is unnecessarily insulting to a well respected member of this forum.
Also, I'm guessing you don't know how old Dave is, otherwise you probably wouldn't have posted that crap.
