TwinForce Now EcoBoost
Old Jan 5, 2008 | 10:17 PM
Topnotch's Avatar
http://www.autoblog.com/2008/01/06/d...ect-injection/
Old Jan 6, 2008 | 12:00 AM
hi5.0's Avatar
"EcoBoost"? (nee Twinforce - wink, wink, nudge, nudge! ) If it turns out well, OH HECK YEAH! So where's the V8 version of the EB?
Old Jan 6, 2008 | 07:44 AM
fordboy97f150's Avatar
The first EcoBoost engine out of the gate is the 340hp 3.5L V-6, This will be the optional engine in the Lincoln MKS starting in 2009 in place of a V-8.....................hmmmmmm 3.5 makes 340...what could a 3.7 make in the stang...
Old Jan 6, 2008 | 09:14 AM
TomServo92's Avatar
More important than the 340HP is the 340 lb/ft of torque!
Also, I've heard the hi-po versions of Ecoboost will go by a different name.
Old Jan 6, 2008 | 09:23 AM
kevinb120's Avatar
I thought the turbo 3.5 in the MKS was supposed to have 415hp?? Unless this is the more sedate engine as the TF wasn't supposed to be in the MKS at all at launch. Who knows, sounds good either way
Old Jan 6, 2008 | 09:49 AM
Boomer's Avatar
So sounds like they can utilize that name if they require 1 or 2 turbo's...
Also TwinForce could still be used I guess on the higher powered V8 TwinTurbo's
The name does convey economy, even if sounding a tad lame.
But lets face it, they can call it BunnyPower, and as long as it produced 340hp and 340ft-lbs out of a 3.5... I could care LESS what they call it
Old Jan 6, 2008 | 10:50 AM
Moosetang's Avatar
They could wind it up into the 425 range, but they're going for max efficiency while still puttting out us much Hp and ft-lbs as possible. I'd imagine that they can monkey with those numbers depending on the application.
Old Jan 6, 2008 | 12:47 PM
well you have to figure too, if people have the power they will use it, hurting mpg rating, and if they make the engine too powerful, the drivline will have to be beefed substantialy...but the mkz..4wd drifting with 400 hp and ft lbs...sounds like a lot of fun
Old Jan 6, 2008 | 02:21 PM
SuperSugeKnight's Avatar
I could see the 4 and 6 cylinder versions called the EcoBoost and the V8 versions called Twin Force.
Old Jan 6, 2008 | 03:13 PM
Evil_Capri's Avatar
Nice 10 Min. video from FMC on the Ecoboost engines . . . oh and a nice Ecoboost Taurus drag race at minute 6:54!
http://www.youtube.com/watch?v=jgilKUwMl2A
Old Jan 6, 2008 | 05:12 PM
V10's Avatar
V10
So when is Ford going to get cracking on putting DI on their normally aspirated engines. With DI the 4.6 3V would run at least 340 HP and get 2 MPH better mileage.
Old Jan 6, 2008 | 06:14 PM
tacbear's Avatar
Did you notice "340+ hp". And if the 3.5 is 340+, the 3.7 will be 360+. Yes I would pimp a Mustang with 360hp+/360ftlb+ and 150 pounds off the front end. That would bring the Mustang v6 pretty close to 50/50 weight distribution.
Old Jan 6, 2008 | 06:45 PM
V10's Avatar
V10
That was the 3.7L Twin Force show car that ran on Ethanol.
I don't remember Ford ever saying that the production version would be 415 HP.
Old Jan 7, 2008 | 05:45 AM
Black331's Avatar
Maybe 10 years from now...
Ford moves at a snails pace...
The other question is what transmissions will Ford put behind these engines as nothing they have can handle that much torque..
Old Jan 7, 2008 | 09:12 AM
Knight's Avatar
Needs to be more Astony
so my mazda cx7 is DI and turbo, is that considered ecoboost?
Old Jan 7, 2008 | 10:02 AM
Moosetang's Avatar
If Mazda is also goign to use the EcoBoost moniker (honestly don't know), then the CX would likely get rebadged with EcoBoost during its mid-cycle refresh. However, its just as likely EcoBoost will be F/L/M only.
The DI manufactuing capacity is still being put together, just like the GTDI capacity. The N/A DI engines will roll as that capacity grows and can accomodate them. Lets see what's in store at NAIAS before we start bleating that nothing's been done, shall we?
Old Jan 7, 2008 | 07:12 PM
TomServo92's Avatar
No. From what I understand, Ecoboost used tech not used in the CX-7 such as a dual scroll turbo and the next generation DI. I believe there are other differences but I'm not sure what they are.
Old Jan 8, 2008 | 02:44 AM
Hollywood_North GT's Avatar
Closet American
TwinForce was a great name. It was a mistake to change it to EcoBoost - which may be more generally descriptive of what the new engines represent - but sounds completely gay.
Old Jan 8, 2008 | 07:34 AM
Knight's Avatar
twin force was definnatly a better name...they could have said the two forces were more power and better efficency.
Old Jan 8, 2008 | 08:27 AM
TomServo92's Avatar
Twinforce may not be gone. Word over on BON is that the hi-po versions of Ecoboost will carry a different name. Perhaps Twinforce?
