General question
General question
Hi there,
I'm new here and have a question. I have a 2007 mustang convertible and I've noticed that under the rear window (on the canvas in back corner) has start to leak when it gets wet. Is there some sort of gutter system I need to clear out? I know about the one behind the battery so water doesn't leak onto my floorboard but the rear leaking is stumping me. Any help?
Fellas, looking for the Speaker Grills/Covers for my 2002 Mustang GT convertible. I need the Two Right Rear Passenger Speaker covers.
if anyone has them for sale. Trying to bring her back to life….
bones311@bellsouth.net
Thank you
Thank you
@sergiojeff
Looks Like Some are Still Available From FORD If I'm Specifying Correctly. Those That are Not You Can Use the Part Number for an Ebay Search. Also ID# Numbers which are Different than Part Numbers Are Often Used For Listings. They would Be Embossed on Part. Usually Similar To Part Number but a Bit Different.
A Pic or two Always Helps To Make Sure We are on Same Page.
Put your Vin in Parts Catalog Below to Narrow Down Choices.
https://www.fordpartsgiant.com/parts...tml?pnc=18978A
No Need to Be Asking Same Question in Multiple Forums.{Spare Parts Co. Posting} We Will See One!
The Wanted Section Would Have Been Best Area to Post Question. No Harm No Foul.
Would Not Hurt to Check Local FORD Dealer & Get Quote with Part Numbers.
Good Luck!
KC
Thank you
Thank you
Good Luck!
KC
protozoan
Oct 2, 2022 07:06 AM
