Add transmission fluid to gas tank?
Old Feb 20, 2008 | 02:30 PM
shatter's Avatar
My mother in law went to a local garage (Firestone) when the check engine light came on in her Taurus. The mechanic said as the engine ages it will run lean/rich alternately and to run a quart of transmission fluid every 4 tanks of gas to remedy the problem. I have no idea what code caused the check engine light to come on.
Anyone ever heard of running tranny fluid in the gas tank? Only thing I can think of is it has detergents to clean the injectors like injector cleaner?!?!?
Old Feb 20, 2008 | 03:19 PM
shatter's Avatar
I think I am going to run some BG44K through her tank and see if that does the trick.
Old Feb 20, 2008 | 03:59 PM
Just as a gut feeling, I would say dont do it, unless he has a written letter telling you to, so if something screws up he'll be liable. Get some regular injector cleaner.
Old Feb 20, 2008 | 04:10 PM
future9er24's Avatar
That sounds a tad absurd..
I would really like to know the rationale behind that advice
Old Feb 20, 2008 | 05:22 PM
codeman94's Avatar
dont do it.....sounds like some "good old boy" that heard somewhere it works but has never tried it.
Old Feb 20, 2008 | 05:34 PM
GRAYPNY's Avatar
What's BG44K?
Old Feb 20, 2008 | 08:10 PM
Dougxox's Avatar
Tranny fluid will blow white smoke out the exhaust when burned. just like blowing a modulator valve.
Old Feb 21, 2008 | 12:28 AM
theedge67's Avatar
I cannot think of why tranny fluid would be a good thing to run through the gas tank. That makes no sense to me. I'm not even sure how the two would mix in the gas tank. The tranny fluid might float on top of the gas, they might mix nicely, they might turn to some sort of sludge that coats the bottom of the tank with 3" of goo...
The point is, these two chemicals were never meant to play nicely with each other, so let's not experiment.
Old Feb 21, 2008 | 01:46 PM
fordboy97f150's Avatar
ive had success with lucas fuel treatment
tranny fluid mixed with gas...sounds ...whats the word...ummm... stupid maybe?? lol i dont know, i wouldent risk it
Old Feb 21, 2008 | 09:04 PM
hi5.0's Avatar
i use lucas fuel treatment too. IDK, put some seafoam in there, rather than trans fluid.
Old Feb 21, 2008 | 09:14 PM
shatter's Avatar
I did some searching on the internet and various forums and found people recommending the following products (in no particular order):
1. Chevron Techron
2. Lucas Fuel Treatment
3. BG Products BG44K
4. Seafoam
It -seemed- like the two most popular were Techron and BG44K and the Lucas was in there close. On the seafoam, either people swore by it or trashed it though it seemed like the majority liked it.
I went with the BG44K from BG Products http://www.bgprod.com/products/fuelair.html
Can only get it at the local car dealerships and garages (not at parts shops that I could find)... the local Toyota dealer wanted $50 for a 11oz. bottle so I bought 5 bottles off ebay for $60.
Old Feb 22, 2008 | 04:51 AM
1999 Black 35th GT's Avatar
1. Chevron Techron
4. Seafoam
I've also used Lucas and it really does make a difference on an older car. Try it out.
Old Feb 22, 2008 | 09:20 AM
Slims00ls1z28's Avatar
Trans fluid in the tank? I know why but never heard that method of implementing it, especially since the transfluid will linger in the tank long afterwards. Last time I used trans fluid outside of a trans was with a carb not Fuel injection. Would be much better off running a little diesel in it every now and then. Neither of which BTW I could see much use in resetting the check engine light. It would help clean deposits but more than likely if something is so dirty it trips a code it more than likely needs replacing. Get the code run and fix the problem, don't trust "mechanics in a bottle", most of the time they hide problems.
Old Mar 3, 2008 | 01:25 AM
bob's Avatar
bob
Originally Posted by GRAYPNY
What's BG44K?
Awesome in a can, or rather its one of the better engine depsoit cleaning products out there. I like to use BG44k every once in a while (it costs around 18 bucks a can) in between uses of Lucas top engine treatment.
Old Mar 13, 2008 | 10:33 PM
edumspeed's Avatar
Legacy TMS Member Pr
Trans fluid on the gas tank? That guy must have mistaken a car with a 2 cycle ATV or scooter!
Old Mar 14, 2008 | 05:53 AM
Bandit1's Avatar
I have used bg44k as well.1 can to one half tank of gas.I honestly could not find or hear about one bad word about the product and it did seem to perk up performance afterwards.I will do it again,,
Old Mar 14, 2008 | 07:57 AM
edumspeed's Avatar
I've used Techron and it works great!
Old Mar 15, 2008 | 07:59 AM
Heet works really well too. Helped a car pass emissions test with just that.
NC14GT
Sep 10, 2017 04:47 PM
CNFLCTD
GT350
Aug 4, 2017 07:08 AM
mx5jhb
Sep 30, 2015 04:44 PM
Evil_Capri
Sep 25, 2015 12:56 PM
