What should I do..?
Old Jul 21, 2013 | 05:29 PM
mustangmike1039's Avatar
What should I do..?
I recently did a tune up so today i wanted to check a few of the plugs and see how there burning. All looked super clean. But cylinder 5 had oil on the spark plug threads. The plug electrode looked fine but the bottom rim of the plug had some black. What does that mean??
Old Jul 23, 2013 | 02:21 AM
calebnaasko's Avatar
Might be running rich.
Old Jul 23, 2013 | 11:15 AM
shaunrc's Avatar
If it had oil on it its not running rich you either have a crack in your cylinder head or your piston rings are deteriorating. Are you sure its oil?
Old Jul 23, 2013 | 03:38 PM
AzPete's Avatar
If the oil is on the threads, it is caused by an external oil leak of a valve cover most likely. Oil on the center and side electrode would indicate internal engine issues.
Old Jul 26, 2013 | 04:36 PM
I will pull the plug again in a couple days and see what it looks like-will take pic this time. Thanks guys
SVS
May 17, 2014 11:09 AM
eric n
Feb 11, 2014 06:30 PM
blairnr67
Mar 5, 2013 03:10 PM
stecz20
Oct 11, 2009 10:37 AM
