Water on the floor? :(
Old Sep 20, 2009 | 10:28 AM
future9er24's Avatar
hey all,
I've had this problem in the Bullitt for a while but i keep forgetting to post about it. after my road trip to SoCal something needs to be done. Whenever I use my AC, water starts dripping down from under the dash and soaking into the carpet, but only on the passenger side. I don't always notice it while itds happening bec i'm never in the passenget seat or my passenger doesnt notice. then the next day i open my car up and it smells like rancid ****. if i leave any clothes or paper on the floor it sucks it up like nothing else.
Pete has said thata the ducting may be clogged and condensation can't escape the normal way. what is actually going on here? and more importantly, how can i make i stop. last night i drove 470 miles with my windows down bec i didnt want my carpets to get moldy
Old Sep 20, 2009 | 10:34 AM
hi5.0's Avatar
Yeah. Check the water drain hole on the passenger side of the firewall near the exhaust manifold/h-pipe joint. Maybe fashion a proper drain tube after clearing any obstruction so the condensation doesn't drip on the hot exhaust piping.
Old Sep 20, 2009 | 11:17 AM
Evil_Capri's Avatar
Is the water cool leaking out, or warm. And is it just water? If there is coolant mixed in with the water your heater core may be on its last legs . . .
Old Sep 20, 2009 | 12:28 PM
You can usually smell antifreeze from a leaky heater core.
Old Sep 20, 2009 | 02:52 PM
I've got the same issue, my A/C is clogged somewhere. It's a major PITA in my jeep to fix, I have to take out the entire dash to clean it. ughhh!
Old Sep 20, 2009 | 03:57 PM
Evil_Capri's Avatar
Usually . . . .
Old Sep 20, 2009 | 03:58 PM
BlueSkyVert's Avatar
My mother's Camry had the same problem. On her car, the hose could be accessed through the engine bay (on the firewall). I found recommendations online to either use a coat hanger or air pressure to clear the obstruction.
Old Sep 20, 2009 | 04:25 PM
jacostang's Avatar
Clog!!!!
Old Sep 20, 2009 | 04:55 PM
Autotooner's Avatar
My C/T is cooler than Arin is.
I was thinking of the accumulator being clogged/bad... but I dunno....
Old Sep 20, 2009 | 05:36 PM
hi5.0's Avatar
The junk thing is, Fox-based Mustangs don't have a drain hose coming out of the firewall. Maybe a softer wire or fine brush (something similar to a gun barrel bore cleaning one) could do the job? Could have something growing in there by now. May as well get the system cleaned out while you're at it.
Old Sep 20, 2009 | 11:54 PM
im fairly certain if it were mixed with coolant it would have stained the white shirt, and various papers, books etc that its gotten wet before..
the water is usually cool when i get to it, unless i dont notice until a hot day and its warm just because.
ive been trying to only use AC when i REALLY have to. i kept my windows down for most of my road trip, but on one day it was so hot the window motor decided to bail on me (again!) thankfully it cooled down and is fine now, but i didnt wanna risk it
i'll try cleaning it out when i have some time later this week
Old Sep 21, 2009 | 09:10 AM
Knight's Avatar
Needs to be more Astony
My 99 GT had that issue, the water was usually really cold. and would splash on my feet if i took a turn fast.
It mostly would happen on passenger side, but if i turned right hard it would go to drivers as well.
clog for sure!
Old Sep 21, 2009 | 10:57 AM
cntchds's Avatar
It's super cold when it comes out. I've had my feet there... I know.
Like I said before Arin, I'm fairly sure that it is just that downpipe that is supposed to let it drip out on the ground. I heard on Car Talk that it usually costs about 20 bucks to just have a shop clean it out.
Old Sep 30, 2009 | 11:50 PM
hi5.0's Avatar
fixed?
Old Sep 30, 2009 | 11:53 PM
nope, havent had time
but AC doesnt get much use now, and its getting cold fairly often. two nites in a row have my poor lil toes been frozededededed
Mpaps
Oct 11, 2017 08:06 PM
Feb 10, 2017 07:12 PM
14_GT/CS
2011 - 2014 GT/CS
12
Mar 24, 2016 12:20 PM
Beouch
Sep 16, 2015 06:14 PM
RMS70
Sep 11, 2015 07:07 PM
