Transmission swap
I'm not sure about the wiring harness, but IIRC you do need a PCM from a manual transmission mustang, or you could have the PCM flashed. Also I believe some modifications have to be done to the engine to install a flywheel for the clutch.
Sorry it's been a while since I researched this.
Try google, that's how I found some info and I believe a write up (with pics) IIRC.
