t-3650
1 Post
Originally Posted by bullitt.04567
What fluid to run? Heard so many opinions. And correct level and quantity?
Did check manual. And its 4 quarts but tsb?? Says 3.2 quarts. Says Mobil 1 but others post no synthetic or use GM syncromesh so this is why i ask?? Because I pulled my hair out with all the opinions. Just wanted more I guess.
1 Post
Use whatever the manual says, you can always check the level when you fill it. I would just use mercon atf. That's what was in it and unless your dealing with some nasty heat issues you don't need anything different.
