t-3650
Old May 6, 2012 | 07:57 PM
bullitt.04567's Avatar
t-3650
What fluid to run? Heard so many opinions. And correct level and quantity?
Old May 7, 2012 | 12:05 PM
stupidgenius36's Avatar
Just Plain Rude!
Check your owner's manual.
Old May 7, 2012 | 01:10 PM
1999Pony's Avatar
You need to run atf. I believe the Ford one is Mercon atf. I don't know the exact amount, I want to say 2-3 pints.
Old May 7, 2012 | 06:23 PM
Did check manual. And its 4 quarts but tsb?? Says 3.2 quarts. Says Mobil 1 but others post no synthetic or use GM syncromesh so this is why i ask?? Because I pulled my hair out with all the opinions. Just wanted more I guess.
Old May 7, 2012 | 06:55 PM
1999Pony's Avatar
Use whatever the manual says, you can always check the level when you fill it. I would just use mercon atf. That's what was in it and unless your dealing with some nasty heat issues you don't need anything different.
Zaksgt
Nov 21, 2011 08:41 PM
