starting issue
![Icon Mrgreen](https://themustangsource.com/forums/images/smilies/icon_mrgreen.gif)
![Biggrinjester](https://themustangsource.com/forums/images/smilies/biggrinjester.gif)
That sounds really similar to my problem, actually... hmm
I haven't gotten it diagnosed or anything yet simply because its not that big of a deal. Maybe I'll get around to it soon
If it ain't broke... Honestly if it's as simple as needing to turn it over two times then you aren't that bad off and bringing it to the dealer to get it scanned just for them to replace a part for $7520948572064525420573456058740294365.99 then you may as well deal with it until it A)gets worse or B) you drive the thing enough that it likes you and it starts every time you try.
Stubborn Bear
TMS Staff
TMS Staff
If it only happens at startup and mainly when the car is cold, might be time to check 1) maf sensor (clean it with electrical contact cleaner) or 2) Idle Air Control valve (IAC) which can be cleaned with carb cleaner.
