Squealing When Turning Wheels
Old 4/13/06, 09:57 AM
mudshuvel319's Avatar
I searched around for a similar topic, but couldnt find what i needed. recently, my car has been emitting a high-pitched squeal when i turn the steering wheel in either direction. i only hear this when stopped or traveling at low speeds, but that may simply be because there is other noise that drowns it out when i'm driving normally. it is definately coming from the front of the car, seemingly behind the wheel.
the power steering fluid reservior is full, i believe the steering pump is fine, the belt is brand new, and i have made no suspension changes to my car. i also looked under the car to see if anything appeared to visually be wrong, but i didnt have anyone to turn the wheels for me while i watched, so i couldnt figure much out. the squealing doesnt happen only when the wheels are turned to the extreme left or right. if they are pointed straight ahead and i make even a slight turn left or right, the noise begins.
if anyone has any suggestions or knows what the problem is, i'd appreciate the help. thanks! -Dan
Old 4/13/06, 10:10 PM
joker's Avatar
My 96 gt made pretty much the same type of noise, under the same circumstances. I kind of ignored the noise thinking it was a bad strut on the front. After about a month of driving it like that I was backing out of a parking space and my passenger side front hit the ground, driving the wheel up into the fender. Turns out the ball joint had completely gone out. I was lucky that it did it backing out though. If it had went out at medium to high speed, the entire passenger fender would have been gone, and I could have possibly been hurt very badly.
Old 4/14/06, 10:23 AM
ok, thanks for the advice; i'd better check that then. im just surprised i'd need a ball joint after only 45k miles. glad to hear you were okay though.
Old 4/14/06, 02:23 PM
chris8519's Avatar
45k on a 2000? WOW!
Can you say: LOW MILAGE!?
good job. And good luck on your problem... I know the ol' Ford Power Steering Pumps ALWAYS make noise. They whine from the day they leave the assembly line, but your sound seems different...
Old 4/14/06, 06:01 PM
<div class='quotetop'>QUOTE(chris8519 @ April 14, 2006, 4:26 PM) Quoted post</div><div class='quotemain'>
45k on a 2000? WOW!
[/b][/quote]
i try not keep the mileage low, in part because i like to avoid problems like. i know some pumps can be notoriously noisy, but this sound does seem different and it only started recently. thanks for the encouraging words!
Old 4/16/06, 12:44 PM
ZipZap04's Avatar
Any luck? It might be your cv joint(s) also. Its done it to my other cars when i was turning and noticable, but they werent mustangs.
Old 4/18/06, 04:48 AM
I jacked the car up and the wheels are tight, so i dont think its the ball joint. ive been trying to check the control arm bushings, but they seem to be good too. i dont have the time to inspect everything at once, so im going pretty slowly right now. thanks for the suggestions.
Old 4/18/06, 09:42 AM
DrunkenDragon713's Avatar
<div class='quotetop'>QUOTE(mudshuvel319 @ April 14, 2006, 7:04 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
Mine's a 2000 GT, bought in late 99, and I have yet to get to 30k... Talk about low mileage...
I asked someone and they also said ball joints... he a mechaniac so I guess that might count for something...
Old 4/18/06, 01:01 PM
Laser98's Avatar
I had a similar problem but it was the tie rod ends (or I think that's what they are called). I punched a small hole in the top of the rubber boot and fulled it with grease and the squeak went away.
Old 4/18/06, 03:01 PM
GottaHaveIt's Avatar
did you do the belt or someone else ? just maybe its the wrong " V " shape for the pully but sounds more like a pump would, I had a 66 Falcan that did the same thing you had described Dan.
Old 4/18/06, 04:09 PM
tricky02GT's Avatar
Soak car overnight in vat of oil. Works every time.
Old 4/18/06, 05:34 PM
63galaxie's Avatar
Ford does have P/S pump problems. My car with a 5.0 has a noisy pump, and a mechanic told me that air was running in the pump somehow...I don't know if thats credible or not but it could be that.
Old 4/18/06, 06:17 PM
Ill try the oil vat as a last resort, but thanks, lol.
as for the belt, it started squealing about a month ago, so i changed the belt, because it did have a few hairline cracks it it. its plenty snug, and still makes the same noise. it very well could be the pump too.
this weekend i'm going to try to take a good look at the whole front suspension, and try to determine exactly where the noise is coming from. like i said, i didnt have anyone to turn the steering wheel while i looked around, so ill get someone to help me this weekend. whatever the noise is, its embarassing as heck to drive with, lol
dohc97
8/3/15 06:26 AM
nismos13s14
1994-2004 V-8
7/31/15 12:55 PM
valanahara
7/22/15 05:13 PM
MRGTX
7/21/15 02:08 PM
Quick Reply: Squealing When Turning Wheels
