sn95 cobra self made push button start!
Bear Eats King...
Bear ****s Bone
Bear ****s Bone
Bear Eats King...
Bear ****s Bone
Bear ****s Bone
Bear Eats King...
Bear ****s Bone
Bear ****s Bone
well i have my pats disabled. so it can start with no key. if you wish to insert a key before starting leave pats on and insert the key. you wont need to turn it but it will need to be there so pats can pick the chip up
Very cool. Could you do a how to post on how you wired it up?
Bear Eats King...
Bear ****s Bone
Bear ****s Bone
No the key is not usable anymore. This mod requires you to pull the ignition switch apart to solder the pins. I guess you could attach to the wires but the main reason I did this is because the key stopped working. So I didn't plan on keeping the ignition hooked up. Either way I can draw a diagram to keep the switch intact and leave the key usable
Welcome!
Seems To Be Some Youtube Vids You May or May Not Have Seen! The Op Has Not Been in Since 2019 So Likely a Response is Not Coming to Thread From Him.
https://www.google.com/search?sca_es...&bih=730&dpr=1
KC
KC
Diode Dynamics
Feb 28, 2018 09:37 AM
