Power window acting up - depressed i can't fix
Old May 9, 2018 | 06:37 PM
crazy-one's Avatar
Hi
Originally, the motor was failing on hot summer days, a common problem with 2003 mustangs. I
removed the motor and regulator assembly. Applied grease to the rubber stoppers inside the motor.
I am able to install the assembly no problem, however.. without installing the motor I try moving
the window up and down and the white guide clips are hitting on the window guide. The clips feel
firm and do not budge nor do they look destroyed.
When I remove the regulator assembly, i can tilt the window as needed and it does not hit. With the
regulator installed, it always hits no matter how i position the window.
Please help
Attached Thumbnails Power window acting up - depressed i can't fix-0.jpg   Power window acting up - depressed i can't fix-1b.jpg   Power window acting up - depressed i can't fix-2.jpg
Old May 9, 2018 | 07:32 PM
crazy-one's Avatar
Video included to help explain
File Type: avi
Rapture
Off-Topic Chatter
Mar 5, 2008 06:44 PM
jmanpatsfan
Dec 26, 2007 06:40 PM
PowerPonyBLue
Sep 3, 2004 09:54 PM
