Pete's 1994 Mustang GT Diary thread
Old Apr 19, 2010 | 01:48 PM
  #1581
edumspeed's Avatar
Legacy TMS Member Pr
Originally Posted by cntchds
Located a FREE white front bumper to replace the fiberglass piece of work that's on there now. I can't wait to pick it up this weekend.
Old Apr 19, 2010 | 01:56 PM
  #1582
cntchds's Avatar
I installed the Koni struts yesterday, but made the mistake of not moving my bumpstops over, so I still need to do that (pain in the...), but really not a big deal in the grand scheme of things.
Not a pain at all. Since I had just taken the struts off the other day all the bolts were easy to take off and it was just going through the motions.
Going to pull the Watts link this weekend as well to hopefully get it better set up, since it's been a pain in the butt lately. It's making a banging sound when I go over bumps at speed, so clearly it isn't articulating freely.
I figured out that the driver's side arm was about 1/8" longer than the passenger side arm. I adjusted, and so far so good. I feel like there is more grip out back, but it's probably just in my head.
Old Apr 30, 2010 | 01:43 AM
  #1583
cntchds's Avatar
Just located some H&R Race front springs. Acquiring those as fast as paypal can send money.
Old May 3, 2010 | 12:21 AM
  #1584
cntchds's Avatar
And the springs are on their way! I'm pretty stoked.
Old May 4, 2010 | 04:11 PM
  #1585
mustangGT90210's Avatar
I will buy Jack Stands!!!
So what's the deal with saleen bumper? I think it looks sweet, but there's clearly something you don't like...
Old May 4, 2010 | 04:18 PM
  #1586
future9er24's Avatar
its fiberglass, crappy and brokedededed
Old May 4, 2010 | 04:22 PM
  #1587
3 good reasons. I approve of a free bumper replacement
Old May 4, 2010 | 05:18 PM
  #1588
edumspeed's Avatar
What happened with the Bullit springs? Don't like 'em?
Old May 4, 2010 | 07:19 PM
  #1589
Bullitt/Mach springs are cool... but theres so much better to be had. if I had the funds mine would be gone too lol. especially if i had better shocks and struts like pete does, and a watts.
its funny to think that petes brokeass GT could outhandle my bullitt now I think.. well, if it had a competent driver its been pretty cool to watch this car get better and better as my bullitt becomes worse and worse.
Old May 5, 2010 | 03:35 PM
  #1590
Reverse the trend there bud
Old May 5, 2010 | 05:09 PM
  #1591
edumspeed's Avatar
Bullitt/Mach springs are cool... but Terminator's are better. if I had the funds mine would be gone too lol. especially if i had better shocks and struts like pete does, and a watts.
Fixed it
And if he decides to overhaul that 5.0L into a stroker, watch out
Old May 5, 2010 | 08:50 PM
  #1592
cntchds's Avatar
I am a big fan of the springs. They are absolutely amazing for stock springs. The spring rate on them is 650lb/in which is pretty stiff(stiffer than your termy springs. ), but the Race springs I'm getting are 750-950lb/in.
I'm also looking for a set of either Race or Super Race rear springs to compensate for the height difference. I'm definitely not going to be doing a stroker motor in this car. I'm hopefully getting a job this summer to add into my "new car" fund... 96-98 Cobra 99-04 GT... or maybe I could reallistically think about that Daytona... Mmmmmmmm.
Old May 6, 2010 | 06:06 AM
  #1593
edumspeed's Avatar
I forgot that mine were vert springs 550 lb/in. But those are still better than my cut and sagged factory ones Good to hear you'll be earning extra money
I'm in the slow process of recovering financially in the hopes that someday I'll get a brand new car or a slightly used one.
Old May 8, 2010 | 01:37 PM
  #1594
cntchds's Avatar
So I guess since spring rates increase slightly when they are cut, maybe cutting a coil off the rear Machs would make them as stiff as the Race springs... That would be cheaper...
Old May 8, 2010 | 02:59 PM
  #1595
Might as well try it and just have a spring fund ready to buy if you don't like it
Old May 8, 2010 | 05:14 PM
  #1596
hi5.0's Avatar
cheap project Cobra: don't (want to) know where that hp figure got pulled out from though. shipping not included
http://honolulu.craigslist.org/big/cto/1726941138.html
Old May 8, 2010 | 10:04 PM
  #1597
edumspeed's Avatar
That won't increase the spring rate, but decrease it instead bec. it will have less coil tension, and by the fact the spring will heat up in the cutting process, it will harm it even more. The old front springs my car had were only cut half a coil, and you saw how bad they were. Don't do it PLEASE! Either sell them or exchange them. You can find a ton of springs on ebay, either the four of them or in pairs. That's how i ended up with my termi springs. But I could use bullit ones at all corners later on.
Old May 9, 2010 | 01:10 PM
  #1598
cntchds's Avatar
And how much would shipping it to the mainland cost?
Old May 9, 2010 | 01:14 PM
  #1599
cntchds's Avatar
Originally Posted by gt40mkII
Hooke's law does not deal with actual changes to the spring itself (which would result in a change to k - the spring constant.)
Short Version
The typical automotive suspension coil spring is made from steel alloy wire with a constant diameter. The formula for this kind of spring is:[/LEFT][INDENT]rate = ( wireDiameter^4 * 1470000 ) / ( coilDiameter^3 * numCoils )
If we cut coils, we reduce the number of coils and the rate, according to the above formula, goes up.
To think of it another way. A coil spring is essentially a torsion bar that is bent around a center axis. Compressing the coil effectively twists the coiled bar. The formula for a torsion bar is:
SR = TR x BD4 / BL x LL2
Where:
SR = Spring Rate
BD = Bar Diameter
BL = Bar Length
LL = Lever Length
Cutting a coil effectively reduces the length of the torsion bar. Again, looking at the above equation for a torsion bar, the shorter the bar the higher the spring rate.
__________________
-- Robert King
http://forums.corral.net/forums/show....php?t=1221224
Old May 14, 2010 | 03:15 PM
  #1600
cntchds's Avatar
Race Springs are here. Can't wait to put them in.
