Part identification f4zb-15a567-ab
It's likely impossible to tell what the relay is for given only a part number. There are likely more than one of them used on your vehicle. The location/use of all relays and fuses is typically in the owner's manual, which can be found online if you no longer have it.
I'm sure... Did you read my post? It's just a part number. There are thousands of those in existence, all with that number on it.
Check which socket you pulled it from, then check the fuse diagram to see what it controls.
Trunk latch relay... if this listing is any indication:
http://www.ebay.com/itm/94-98-Mustan...-/331136046585
And you can see it in the pictures, so I bet it is.
However, it's a relay. Relays can be used for all sorts of things, not just latches and radio amps.
Hope that helps!
Hope that helps!
